Wheel bearing question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Redfrog, Jun 3, 2001.
  1. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    Im replacing my wheel bearings and I can't remember
    if you torque the inner spindle nut. If you are suppost to
    what do you torque it to? Help!!!!!!!!!!!!!!!
    if it matters it is on a 10 bolt in a 79'
    HEY Fords!!! how many flushes does it
    take to get rid of you
  2. TheGeneral
    TheGeneral 1/2 ton status
    Feb 22, 2001
    556
    NC, USA
    Hey, I think it is like torque to 50 lbs while rotating rotor (spindle), then back it off 90 degrees. Then torque to 35 lbs while rotation, then back off 3/8 degrees. I think this is for your year k5. Earlier ones are just a little different. The torque specs are on the adjusting nut. The lock nut to 80 lbs. I just checked this with the manual, and those are good numbers. LOL (luck not laughs)
    If you ain't hurt, you ain't playin' hard enough.
    The General<P ID="edit"><FONT SIZE=-1>Edited by TheGeneral on 06/03/01 08:21 AM (server time).</FONT></P>
  3. K5RON
    K5RON 1/2 ton status
    Apr 14, 2001
    219
    I did mine that way and the 3/8 "backoff" seems to make the bearing have too much play. Could this be a typo? Was it a Haynes manual? 1/8 "backoff" produced what I deemed a more desireable play. Just didn't seem right when I back it off 3/8 turn!
  4. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    my chiltons says torque to 50, back off and then torque to 35... then second spindle nut torques to at least 80
    [​IMG] <font color=blue> Jeff </font color=blue> [​IMG]
  5. K5RON
    Apr 14, 2001
    219
    First "torque" seats the bearings and races.....second "torque" preloads the bearings.....I used new bearings and in fact the hub was also new. The only old part associated with the wheel bearings was the spindle. This leads me to believe that the 3/8 "back-off" (On the second torque) is a typo.
    Ron
  6. Redfrog
    May 4, 2001
    753
    IL
    Thanks for the help. I think I will try the 1/8 turn and see how it works out.
  7. TheGeneral
    Feb 22, 2001
    556
    NC, USA
    K5ron,
    Just a quick lesson for me on preload. I read it all the time. I do it when working on bearings, but just how the %*(does it work in reference to preload. I get it in the diff, but not on reference front wheel bearings. What is it pre loading, the weight of vehcile, wheel, what. Sorry for the dumb question, but it is bothering me and I don't want to be an idiot when talkin this stuff. Thanks and have a laugh at my expense.
    The General
