Wheel Bearing Repack Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BettyBurb, Jul 26, 2003.
  1. BettyBurb
    BettyBurb Registered Member
    Dec 14, 2002
    52
    NorthEast Colorado
    I am repacking wheel bearings today. I am wondering should I just wipe all the excess grease out of the hub/rotor assembly and then wipe any grease off the rotors with some rubbing alchohol. Or should I get some engine cleaner or brake cleaner and get all the grease out of the hub/rotor assembly ???
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I always use solven and a part cleaner brush. Get ALL of the old dirty grease out. Usually with the hubs I just use a rag to wipe out all the old grease.
  3. BettyBurb
    Dec 14, 2002
    52
    NorthEast Colorado
    "I always use solven and a part cleaner brush. Get ALL of the old dirty grease out." - You mean get all of the grease out the bearings, right ???
    "Usually with the hubs I just use a rag to wipe out all the old grease." - You mean the rotor/hub assembly ?
    I am getting the grease out of the bearings themselves with a soak in solvent. I just wiped all the grease out of the hub/rotor assembly, and it seems to me that it would be fine.
  4. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Yep thats how I do it. Just make sure everything is clean and you'll be ok /forums/images/graemlins/thumb.gif
  5. BettyBurb
    Dec 14, 2002
    52
    NorthEast Colorado
