wheel bearing replacement
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by creampuff90k5, Jan 13, 2003.
  1. creampuff90k5
    creampuff90k5 1/2 ton status
    Feb 15, 2002
    142
    New Jersey
    Recently, I noticed my front wheel bearings had developed a hideous amount of play, but since the weather here in NJ has been COLD, I was trying to put off replacement for a while, but... Now there's a noticable grinding/vibration, so the time has come.
    My question is: What do I need to have on hand in terms of special tools (spanner wrench, axle socket?) and parts? I'd like to do this job in one shot without running back and forth to the parts store!
    Thanks.
  2. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    a "wheel lock" removal tool
    its basically a REALLY big socket
  3. RockyRider13
    RockyRider13 1/2 ton status
    Jul 11, 2001
    102
    Kansas
    yea, it is cake. Just get the bearing axle socket like was mentioned, and a set of snap ring pliers. That is on top of allen wrenches (for the brakes and hub cap).
  4. Suffergauge
    Suffergauge 1/2 ton status
    Aug 1, 2002
    153
    Olympia, Wa.
    The socket for the spindle nuts is a must have. It has 4 prongs sticking out of it, and find the one for your application. Snap ring pliers, torque wrench, grease, the rear seal (with the spring in it), and a manual. DO NOT put this off any longer, with the right parts it can be done in an hour. Good luck
  5. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    You just mentionned that you started hearing grinding, that means you will have to most likely change the bearings and the races whic will require a little more than just adjusting. Never put off anything like bearings, you could have done it in 30 min per side before or even less if you've done it before. Now it might take you a couple of hours and more $$$$.
    /forums/images/graemlins/frown.gif
  6. creampuff90k5
    Feb 15, 2002
    142
    New Jersey
    Thanks for your input everyone. It looks like the only thing I need to buy or borrow is the special socket.
    The grinding noise does suck, but I was planning to replace the races anyhow while everything was apart. I have a drift and a few scraps of wood that I hope will coax them out...
  7. 82K5_6.5L
    82K5_6.5L 1/2 ton status
    Dec 4, 2002
    439
    Tucson, Az
    yea dont put this off any longer..before i got my blazer, the previous owner let the bearings go bad and the wheel almost fell completly off, there is chucks of ashpalt on back side of the plate that covers the disc brakes. instead of it being round it is now flat. they are really easy to fix, do like everyone says, snap ring pliers and some time... /forums/images/graemlins/wink.gif
  8. will89
    will89 1/2 ton status
    Oct 21, 2002
    104
    nomad
    Anyone know the size on this? (89 half ton 4wd)
  9. CooknwithGas
    CooknwithGas 1/2 ton status
    Nov 27, 2001
    332
    Istanbul, Turkey
    The races should come out with a long, skinny punch. Just put the punch up against the inside wall of the hub and pound the race evenly all the way around utill it drops out. Make sure the hub is resting on a good solid peice of wood on the floor, or stable work table. That was the one thing on my truck that came apart without a huge ordeal. Replace all the races while you are at it.
    Good luck.
    _____________________
