wheel bearing welded to spindle...any sugestions?
Discussion in 'The Garage' started by Triaged, Jan 23, 2004.
  1. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    My driver's side outter wheel bearing desided to weld itself to the spindle /forums/images/graemlins/angryfire.gif
    I have a new spindle (if needed) and will buy new bearings but first I need to get this thing off. I might just have to beat on the rotor but then I would have to replace that as well.
    Any help on getting this thing off.
    If it matters it is a 2nd design 8-lug D44.
  2. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    get a puller. Put the middle on the axel shaft then hook(or chain) the ends to the wheel studs. that might do it? /forums/images/graemlins/thinking.gif
  3. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Might have to use the blue flammed wrench, and cut the bearing until it comes off.
  4. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Good idea...I think I have one big enough...brb.
  5. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    This is the method I used when this happened to me. Can you say 'proper bearing pre-load and grease'? /forums/images/graemlins/rotfl.gif
  6. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Got it off. Glad I have that HUGE puller. If I wasn't so ready to take the 12ga. to it I might have thought of it /forums/images/graemlins/crazy.gif
    Thanks for the help /forums/images/graemlins/thumb.gif
  7. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    What's bearing Pre-Load ?
  8. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    /forums/images/graemlins/cool.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/pimp1.gif /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/wink.gif That prety much sums it up /forums/images/graemlins/smirk.gif
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    Oh brother. /forums/images/graemlins/rolleyes.gif Just STFU already. /forums/images/graemlins/tongue.gif
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That's not a stupid question compared to what is ball joint preload? Or what is pinion bearing preload?
  11. thatK30guy
    Jan 12, 2001
    32,076
    55
    Tim, do a search on Executioner and ball joint pre-load. You will quickly find out that those two are what drive everyone on this site crazy. That fella was nothing but obsessed with ball joint pre-load so badly, its not funny anymore.
    BTW, Executioner goes way back before you joined this site. He rarely posts anymore and still drives some of us nuts with those dumb pre-load comments.
  12. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Maybe he pre-loaded his head too much when he inserted it into his a** /forums/images/graemlins/smirk.gif
  13. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Preload...what the hell is that /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/confused.gif
    I still think it is funny...
    I never had a problem with Executioner's "know and understand ball-joint preload" posts. I think they did alot of good for people that would think you can just slap new ball joints in without adjusting it.
    On the preload thing I never went along with the factory spec on adjusting the wheel bearings. I think it leaves them way too loose. I alwasy crank on it while spinning the wheel, loosen the nut, and tighten it as much as I can by hand (using the spindle nut socket).
    And just for all you that were wondering the bearing wasn't doing so hot when I got the truck and I don't think it liked all the water in the hub /forums/images/graemlins/tongue.gif /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/1zhelp.gif from this summer and last winter, and the summer before that.... /forums/images/graemlins/grin.gif
    Executioner,
    Nice to see you are still lurking around.
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Besides the search feature being disabled, it might be funny to do such a search.
    However, I remember the posts as it was not before I came here. It might be before I registered as a user but I clearly remember you going off on him about ball joint preload, that's why I mentioned it. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    I might be an ass, but at least I'm not a dumbass. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  15. thatK30guy
    Jan 12, 2001
    32,076
    55
    I keep forgetting the search feature is down. /forums/images/graemlins/tongue.gif
    How about going to Exe. profile and click on all his posts and go back and read some of them. /forums/images/graemlins/thinking.gif I'm gonna bet 90% of his replies have ball joint pre-load in them. /forums/images/graemlins/rotfl.gif
  16. Executioner
    Feb 22, 2000
    1,530
    Yup, thats what I meant !
    I have seen the spec. anywhere from 414 in/oz. to
    45 lbs/ft.
    Looks like their is a lot of room for opinions.
    Now if I could only see them with my procto/scope !!!!!!!!
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I remember reading the posts when they were new. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
