Wheel bearing
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by snowtoy, Oct 11, 2002.
  1. snowtoy
    snowtoy Registered Member
    Mar 18, 2001
    30
    Norway
    I have to change my wheelbearing on my 10 bolt rear, what must I do to get my axlesshaft out??? /forums/images/graemlins/k5.gif
  2. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Pull the diff cover, loosen the set screw on the differential cross pin, slide out the pin. With the tire/wheel/drum off, press in on the axleshaft and then remove the C clip on the end of the shaft. Slide it out.
  3. dyeager535
    26,979
    Wheelbearings eat into the axle too, make sure the bearing is a problem before you rip it out, and if the axle is worn, its a better bet to go with a repair bearing than a standard bearing.
  4. snowtoy
    Mar 18, 2001
    30
    Norway
    well so I open my rear axle just to find out that right axleshaft must be changed, It's been used offset bearings there before.
    AND !!! My open diff is bad very bad. so I have to change it to (put in a locker) or change to a other rear axle. /forums/images/graemlins/frown.gif
  5. dyeager535
    26,979
    For the cost of another bearing, locker, and axle, (plus your time! Setting up the new carrier, tear down, cleanup, etc) you can be into another complete axle assembly (front and rear probably) in either a 10/12 bolt or 14 bolt combo.
    Add up what the "fix" will cost you, (lessee...rebuild kit: bearings, seals, races, shims for rear axle about $100, locker...$200? New axle $150, etc) and if you need beefier stuff, compare that with what you can get another pair of axles for.
  6. snowtoy
    Mar 18, 2001
    30
    Norway
    Hi! I just bought me a sparepart truck so now I will change axles, to bad it's 10 bolt on this one also, but all parts in it is new .
  7. dyeager535
    26,979
    Swapping axle assemblies in your case is going to be easier than replacing the wheel bearing. : )
    Did you get the same gear ratio?
