Wheel bearings and races
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rampage, Oct 4, 2001.
  1. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,259
    72
    Humboldt/Pacifica, CA
    Where do you get your good quality wheel bearings, races and seals from? I know Napa has good quality parts, but do they make the best?
    E PLURIBUS UNUM
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Autozone sells TImken. IMO they are the best. tHey are made in the USA. OE supplier.
    John
    <font color=blue>"When all else fails, read the instructions, or get a bigger hammer"</font color=blue>
  3. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    A friend that races stock car and another races dragsters use more extensive stuff to race with but both use Napa stuff on their other vehicals...
    C'moe
    Kill Roy was here!
  4. taterblazer
    taterblazer 1/2 ton status
    Feb 2, 2001
    277
    Boise, ID
    Napa is good stuff. I would only go for the best if they don't cost much more. Your bearings get a lot of abuse from 4x4ing. Foreign matter will destroy the best bearings as well as good bearings.
  5. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    The key is to buy MADE in the U.S.A. ONLY!!!! make sure the race and bearing are stamped with USA. oh and use National Seal for the seal!!
    <a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
  6. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    I had a 14BFF that would leak with anything but GM seals. I've run nationals in my other 14BFF with no problems though. If you have the time, I would order the GM seals.
  7. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    JKust be carefull if you go to NAPA. THey are WAY more expensive!
    Surfing is Life...
