Wheel Bearings (front)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BowtieBlazer, Sep 2, 2001.
  1. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    My front wheel bearings are shot so i purchased all 6 of them? Atleast 4 inner & outter.... and a steel sheath looking sleve they call a bearing i guess.....In the Chilton's manual they say a special spanner may be required for 4x4's...anyone done this? Sound like i got the right parts? and did you have to use a spanner?
    1985 GMC C-10 Shortbed
    1984 Chevy K-5 Blazer
    1982 Chevy C-10 Longbed
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Sounds like you got everything you need - I'm not sure what the little sleeve deal is though, I know I've never seen one.
    The only thing you'll need special is a hub socket - it looks like a large socket with 4 little ears on it.
    1 tequila 2 tequila 3 tequila Floor
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. BowtieBlazer
    Jul 15, 2001
    2,462
    Rental tool I assume? Or cheap as a regular socket?
  4. ScoobyDann
    ScoobyDann 1/2 ton status
    Mar 9, 2001
    305
    El Paso, TX (Far West Texas near Las Cruses
    i think it's the race, where the bering rests and spins on, i usually dont change them but check the old ones, if you need to change it get a thick flathead screwdriver and hammer it out but dont throw it away, put the new one in and slightly hammer it in, once you cant get the hammer on it anymore, flip the old race on top of the new one (thick side of old one one on top of thin side of new one)and hammer it down on top of it. you will hammer it down into the hub but since you flipped the old one you can turn the hub over and hammer it out w/ the screwdriver. hope this helps
    danny
    Hut in the well is goin on in here?
    sun desert offroad <a target="_blank" href=http://4x4.alloffroad.com>4x4.alloffroad.com</a>
  5. dragricinMT
    dragricinMT 1/2 ton status
    Jul 21, 2001
    135
    Billings Montana
    The other bearing should be a spindle bearing. Does it have the needle rollers in it?
  6. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    It's good to get your own - Mine cost $15.00 and change at Big A. It's one of those things that you'll find you always use, and it'll make you actually pack your bearings regularly.
  7. the special 4 prong socket is around 12 bucks. should buy it and always have it in your tool box in your truck.
    <font color=blue>Striving for K5 world dominance</font color=blue>
  8. BowtieBlazer
    Jul 15, 2001
    2,462
    cool deal thanks all for all the info...yeah that's it a "race"
  9. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    well you are 2 races short then. if you like buying tools you can get a special punch with a football shaped head for races. as no one would ever use a screwdriver as a punch or prybar right fellas?
  10. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    OK - I've got it now[​IMG] I was thinking like a speedy sleeve.
  11. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Hell - I've got an old set of screwdrivers especially for that purpose[​IMG]
  12. ScoobyDann
    Mar 9, 2001
    305
    thats what Ive always done. every thing still works
    sun desert offroad http://community.webshots.com/user/scoobydann
  13. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Thats what craftsmans are for. Beat them up, destroy yhem, then return them.
    86 Jimmy 4"lift 35"MTRs Other cars 69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  14. 4x4_76
    4x4_76 1/2 ton status
    Jul 22, 2001
    628
    Ylämaa, Finland
    Should there be some sort of locking plate or washer under the nut?I just took apart my trucks right front because there was quite much play on the bearings and I just wondered that will it stay tight without lockwasher.
