Wheel Bearings on a 14 Bolt...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Waxer, Jun 3, 2000.
  1. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    I am about to repack the wheel bearings on my 14 bolt, but after reading the Haynes manual, it says I need another special locknut socket for the task. Anyone know which one they are talking about? Do I really need another specialty tool? thanks in advance. [​IMG]
  2. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    No, you do not need the specialty socket. You can use a punch to remove the nuts, notice I didn't say chisel, cause chisels screw up the spindle nuts!! And, why are you repacking the bearings? They do not need grease, as they are lubricated by the diff oil.
    ken
  3. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    Yeah you need a special socket. Luckily my friend had one already so I didn't have to buy one. He got his from snap-on, and he said that there were a few different ones, so know what year your axle is. The socket was 3/4 drive and about $70.00. You might try napa for the socket also.
    BIGJ
  4. titanic
    titanic 1/2 ton status
    Mar 27, 2000
    498
    north alabama(huntsville)
    Ken's right!!!!!!!!!!!!!
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
  6. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Oh yeah, the punch will work for getting them off, but you can't torque the nuts back down properly using a punch. The manual says to torque the nut to 50 lb/ft, while rotating the hub. Then back off a quarter turn and torque to 35 lb/ft and lock the nut in place. You can get "close enough" if you have to use a punch in an emergency, but using the right tool makes the job much easier! [​IMG]
    <font color=blue>http://ThunderTruck.ColoradoK5.com</font color=blue>
  7. BIGJ
    896
    Central Arkansas
    I agree. Having the right tool is the best way to go. The original owner of my axle had used a punch to remove the hubs. The slots or keys in the nuts were so rounded from the punch that I couldn't remove them with the right tool. I had to use a punch after all. I had to get new nuts and lock rings. It just makes sense do it right and save parts in the long run. Just my .02.
    BIGJ
  8. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    bought tool from napa, 38.00
    your right. I don't understand the jeep thing!
  9. dumbfounded
    dumbfounded 1/2 ton status
    May 20, 2000
    176
    Castalia, NC
    I agree with Ken. If it ain't broke dont try to break it. Changing diff lube will be just like repacking bearings. If you want you can send me your axle I'll "repack" the bearings and send it back in a few years. Mean while you can borrow my 12 bolt......
    Wasn't me.............
