Wheel bearings
Discussion in 'The Garage' started by 71 Blazer, Nov 10, 2006.
  1. 71 Blazer
    71 Blazer 1/2 ton status
    Jul 16, 2005
    184
    windsor virginia
    I just replaced the wheel bearings on the passanger side of my 76 GMC. Took it for a test drive and it rides fine but the passanger side seems to be running hotter than the drivers side. Is this because the new bearings have tighter clearances and the new grease is thicker or did I do something wrong? My guess temperature wise is that it is getting up to 180 just hot enough that I can hold my hand on it for a few seconds, this is right after I pulled off the highway. It cools down on the back roads, same as the other side, just hotter. Also the new grease I used is not the high temp red stuff that was in their originally, it is made by Valvoline and it good from -20 to 475 degrees.
  2. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    i believe ive always done wheel bearings on both sides at the same time. as long as you've got the right parts installed and torqued correctly i wouldn't worry about it.
