Wheel gonna fall off....
Discussion in 'The Garage' started by naveycantwo, Nov 27, 2003.
  1. naveycantwo
    naveycantwo Newbie
    Oct 8, 2003
    4
    My suspension needs some work, I know this... But to be sure of what I need to do to get this fixed. What would need replaced if at starting off your tire starts shaking like a wobble, there is a crap load of play in the steering wheel, and I think it has somthing to due with the pitman arm maybe? /forums/images/graemlins/thinking.gif
  2. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    Have you checked the torque on your nutz?
    Also jack up your truck so that the tire is off the ground and try shaking it back and forth toward the center of the truck with your hands. If it has a lot of play your ball joints are probably shot.
    -Andrew /forums/images/graemlins/usaflag.gif
  3. 88jimmy4x4
    88jimmy4x4 1/2 ton status
    Oct 19, 2003
    947
    3
    Houston, Texas
    I agree
  4. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    Check the ball joints first, if they're ok then see if it's your wheel bearings. I drove around with a buddy who's wheel bearings were so toasted when we went to replace them, the only thing holding the wheel on was the brake caliper /forums/images/graemlins/eek.gif I don't ride in his truck anymore. The lack of maintenance scares the poop out of me /forums/images/graemlins/crazy.gif
  5. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    I agree with all of the above Plus....Check for play in the tie rod ends....easier than ball joints, also more common...it's a $100 fix (using generic parts)...thinkin' if the front end is that shot, bad wheel bearing are practically a gimme...if you end up rebuilding, MOOG is the way to go...little spendier, but worth it in the long run..,
    other causes of slop/play in the wheel could be worn steering gearbox (somewhat adjustable), idler arm, rag joint shot....
  6. clubba68
    Dec 6, 2002
    1,511
    Yeah, you can also tighten the steering a little at the steering box as said above by adjusting the screw on the top of it. If yours is anything like mine was (covered in filth) it takes a little cleaning to get down to the point where you can see the screw, but it is there. If I remember correctly all you need is an allen wrench.
