Wheel hop problem....traction suggestions???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by twenty_below0, Mar 3, 2002.
  1. twenty_below0
    twenty_below0 1/2 ton status
    May 16, 2001
    436
    Haines, Alaska ...u.s.
    OK, I am currently running a 300 hp 350 and am going to drop the new one in here in about 6 weeks, approx. (420 hp) so I would like to get everything ready, currently if I mash it it will spin both rears and they start hopping Violently on pavement, I am running a lock right in a beefed 12 bolt, do they make something to help me out with out limiting my travel (flex ability),on hard dirt or any other ground condition they dont hop just pavement . thx all suggestions greatly appreciated!!
  2. 87GMC
    87GMC 1/2 ton status
    Nov 5, 2001
    653
    Olathe, KS 66061
    Are you running lift blocks? This can contribute to wheel hop. Sams offroad has a cool traction bar. I think it's under $200 and doesn,t effect flexibility.
  3. twenty_below0
    May 16, 2001
    436
    No blocks, just easy ride springs and Nitro 8000 single shocks, I will check out sam's thx
  4. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Sounds like you've got too much power. Maybe you could swap in a mid 80's stock 305 to cure wheelhop problem. /forums/images/icons/smile.gif
  5. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    What size tire are you running? The larger the tire, the harder to control wheel hop on pavement, especially if its an off road tire... mine does it too with worn out 33's.
