Wheel hop...
Discussion in 'The Garage' started by Mike's '84, Dec 8, 2003.
  1. Mike's '84
    Mike's '84 Registered Member
    Jul 24, 2002
    46
    Stockton, Ca.
    When I brake on a freeway off ramp or anytime at high speeds I get a bad hop. New drums and shoes both sides...tires new too, and in balance. Does fine at freeway speeds until I hit the brakes. Not sure about the rotors... not getting any bad pulsing from the front though. Any ideas would be great...and a great help to me.
  2. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    how about your shocks?
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Check your tie-rod ends. When they get really sloppy, applying the brakes will basically make your front tires go from looking like /\ to \/ and back and forth...thus creating your "hop."
    Worth a look anyway.
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Warped rottors would be my guess, but it should be noticeable at slower speeds too. I always have my rotors checked-n-trued when doing brakes. Fairly cheap to replace too if they are warped.
  5. gravdigr
    Apr 15, 2003
    1,129
    Tyrone, PA
    I believe his post stated he is not getting hop in the front, just the rear.
