Wheel Lesson
Discussion in 'The Garage' started by PsRumors, Nov 12, 2006.
  1. PsRumors
    PsRumors 1/2 ton status
    Nov 11, 2006
    626
    Cartersville, GA
    Hi everyone! I have an '85 k20 Burb. This is my first Chevrolet and I need some wheel lessons. It has the 13" Brakes on the 14 bolt and a 10 bolt up front. I know with 15" wheels there is grinding to do to get them to fit. Will 16" fit with no grinding?
    What is stock back spacing? What is run to get a slightly wider stance? I will be going with a 2.5" lift and 33's.
    Thanks for the help
    Ron
  2. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,859
    282
    Truckee, CA
    16's will fit no problem.
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    16's will fit perfectly, 15's will, with some grinding up front, i had some 15x8 black steelies on the Burb for awhile, found out they were kind of a weird backspacing something like 3.75, they made the edges stick out just slightly, not enough to make it look weird, but enough to give it alittle more agressive look.
