wheel lockup in 4 wheel *updated to 4hi being busted*
Discussion in 'The Garage' started by Kyle Strong, Jun 4, 2006.
  1. Kyle Strong
    Kyle Strong 1/2 ton status
    Sep 26, 2005
    280
    Eugene, OR
    Here's a question for y'all. When I drop my t-case into 4 (hi as it turns out, thought it was lo as well), the front tires lock up. When I put it back into 2 wheel it's fine again. :confused: Any possibilities? I did just get done pretty much rebuilding the front end, but it did this before I rebuilt it. Thanks
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    What do you mean by locking. I could take it as "working" or "not working"
  3. Kyle Strong
    Sep 26, 2005
    280
    Eugene, OR
    sorry. The wheel ceases to rotate. I can hear it skidding along the ground.
  4. readymix
    May 30, 2004
    6,706
    26
    Siezed spindle bearings
    Broken spiders
    Broken u-joint.
    Does it change of you shift the transfercase or when you lock/unlock a hub?
  5. Kyle Strong
    Sep 26, 2005
    280
    Eugene, OR
    It's when they're engaged and the case is shifted. It can be shifted into 4 without hubs locked and it doesn't do it, IIRC. I can see the u/joint, it's fine. Don't know about the rest
  6. readymix
    May 30, 2004
    6,706
    26
    Could be anything I listed above then
  7. Kyle Strong
    Sep 26, 2005
    280
    Eugene, OR
    so pull diff cover and look for damage?
  8. readymix
    May 30, 2004
    6,706
    26
    That and disassemble the hubs all the way down to the knuckle and clean/replace/grease everything.
  9. Kyle Strong
    Sep 26, 2005
    280
    Eugene, OR
    I just disassembled the hubs down to the knuckle and repacked the bearings, greased everything and installed new hubs, so I doubt that's the problem. Guess I'll pull the diff cover and inspect the gears
  10. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    Dont waste any time do you? 9:06 to 12:03.
    I wish I was so motivated. :D
    Also: I have no idea what is wrong. I wish I could help.
  11. Kyle Strong
    Sep 26, 2005
    280
    Eugene, OR
    LOL no way man! Sorry for the confusion. I did it two weeks ago 'cause I needed to! Damn, I wish I was that motivated too! I could have done it easily, but I didn't need to, and was too busy sitting on my ass watching T.V. :haha:
  12. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    On the wheel that is locking up......lock in the hub on that side only and do not put it in 4WD and see if it trys to lock. If it doesn't, have someone look at the axle while it is moving. (Do I need to tell you to be safe doing this??)
  13. Kyle Strong
    Sep 26, 2005
    280
    Eugene, OR
    Safe...what's that?:eek1: :haha: Anyway, I'll give it a try. If I have someone look at the axle when I'm driving and it's not locking up, what am I looking for?
  14. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Anything unusual. Inner flopping, ujoint contacting knuckle,outer flopping, axle not turning, sparks, noise, etc.
  15. Kyle Strong
    Sep 26, 2005
    280
    Eugene, OR
    I'll have my dad check it out soon. Further inspection shows BOTH wheels periodically lock up. They'll turn, lock up, free up, lock up, etc.
  16. johnathan
    johnathan 1/2 ton status
    Sep 26, 2005
    376
    Ocean Springs,MS
    I'd pull the diff cover.Sounds like you got some gear stew cookin up there
  17. goldwing2000
    goldwing2000 Guest
    Yeah. Sounds like some kind of grenaded locking/limited slip device inside there.
  18. Kyle Strong
    Sep 26, 2005
    280
    Eugene, OR
    damn...that would explain the noise I hear every now and again that sounds like metal grinding.:eek1: :o :haha: I've had more important things regarding my truck on my mind recently, and since it was only occasional and not severe, I ignored it:doah: Seems like I should give it some TLC, huh?
  19. Kyle Strong
    Sep 26, 2005
    280
    Eugene, OR
    *update*
    Well, I pulled the diff cover, and other than some nasty ass fluid, everything looks fine. I jack up the truck, lock in the hubs, drop the t-case into 4hi, go to turn the wheel, and the carrier, ring gear, and front drive shaft stop turning, plus I feel some resistance. The spiders are still rotating, but that's it. Is that normal?:confused:
  20. Kyle Strong
    Sep 26, 2005
    280
    Eugene, OR
    Now that I think of it, could it be my t-case? Because when I have the hubs locked without the t-case engaged it rotates freely. Busted something in my 203 perhaps?
