wheel lug studs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by xnoahx, Sep 21, 2001.
  1. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    The Studs on my driver side front wheel are all pretty stripped and gennerally messed up. The bolts still go on but i dont know how much longer its going to last. How do i fix this? Do I need to get a whole new rotor?
    My 73 K5 <a target="_blank" href=http://www.geocities.com/xk5blazerx/73k5.htm>http://www.geocities.com/xk5blazerx/73k5.htm</a> 350/TH350/NP203, Q-jet, Edelbrock intake, Vortec heads, 4" lift, and 36" TSL's
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Nope, just remove the rotor then press out the old studs. Press in the new studs and you're ready to put it back together. I would go ahead and clean/grease the bearings and replace the seals while it's apart. [​IMG] Oh yeah, don't forget to yank the spindle and grease the little needle bearing inside the spindle that the axle shaft rides on. That one often gets overlooked. [​IMG]
