wheel nuts- 3/4 ton to 1 ton dually
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by R72K5, Nov 21, 2002.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    came acorss oddity- lugnuts on the 74 3/4 ton 14 boltFF are smaller than the ones on the 82 1 ton dually 14 bolt FF
    odd ? or correct ?
  2. 77fixer
    77fixer 1/2 ton status
    Nov 22, 2001
    464
    Meridian, ID 83646
    Same bolt size, just a larger nut on the dually. The dually nut is also a different taper so you can't use a dually nut on a single wheel or the other way around. Probably has to do with the plate that is used with the dually wheels.
    Brett /forums/images/graemlins/burb.gif
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    awesome, good to know, means i'll have to find 16 dually nuts, also, hmmm.,,.,.
    thanks!
