wheel offset?
Discussion in 'The Garage' started by johnathan, Nov 7, 2005.
  1. johnathan
    johnathan 1/2 ton status
    Sep 26, 2005
    376
    Ocean Springs,MS
    I'm lookin at some american eagle wheels.However I don't get the offset.
    Howis that measured from where to where? example 16x8 offset is -4
  2. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    some wheels are + offset while others are -????
  3. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    It's the distance from the inner edge of the rim to the WMS (wheel mounting surface). To measure it, lay a rim on the ground so the back side faces up. Lay a straight edge on the edge of the rim and measure down to the WMS.
  4. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    gotcha so more of the wheel will be to the outside with the -4mm
  5. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Zero offset puts the WMS in the middle of the wheel. i.e. on a 16x8 wheel that gives 4" backsacing.
    + offset puts more of the wheel inboard (more backspacing), - offset puts more wheel outboar. (less backspacing).
  6. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    hey preeciate the help!!!! :bow: :bow: :bow:
