Wheel question....16" vs 15"
Discussion in 'The Garage' started by ranger3, Oct 20, 2003.
  1. ranger3
    ranger3 Registered Member
    Oct 9, 2003
    6
    Wheel question....16\" vs 15\"
    Will a set of 2002 Z71 16" wheels fit on a 1989 Blazer that came with 15" wheels from the factory? Both are 6 lug, 4 wheel drive.
    If the 16" wheels will fit, would the speedometer/odometer need some kind of adjustment to give accurate reading?
    Thanks /forums/images/graemlins/thumb.gif
    David
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Re: Wheel question....16\" vs 15\"
    1. yes
    2. the overall height of the tires is what detirmines if the speedo will need to be recalibrated, not the wheels.
  3. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    You might want to check the backspacing, I think the new IFS have a lot of backspacing that might not work. You might have some tie-rod/steering linkage issues. But the bolt pattern is the same so worst case scenario you can use some wheel spacers.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    In addition to that you might need to check to see if the hub clears.
  5. morphed86k10
    Jun 25, 2001
    463
    Reno Nevada
    oh yeah, good call /forums/images/graemlins/thumb.gif
  6. reeser
    reeser 1/2 ton status
    Oct 8, 2001
    434
    Hayden Lake, ID
    no nope nadda
    /forums/images/graemlins/deal.gifthe ifs rims will not fit the solid axle trucks. i tried it. sorry pal. the backspacing and the hub hole is not big enough.
  7. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    Same lug pattern, but the center hole is too small and the backspacing will cause problems.
