Wheel question..
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rocko, Aug 19, 2001.
  1. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Okay.. My axles are home.. 8lug Dana 44 and 14 bolt FF.
    I was told to use 15x10 8 lug rim's.. Cause 16.5's being an odd size.. when deflated.. tend to pop off the rim.
    Would this be best going with 15x10 8 lug's? I have brand new 35's I'd hate to sell.. Hoping I could just re-use my tires and not spend a fortune on 16.5 inch rim's and equivalent tires.
    And if i use 15x10's.. will I have to grind down the front caliper's on the Dana 44?
    What kind of clearance do 15x10's have on a one-ton rear end ?
    Thanks in advance.
    I haven't failed, I've found 10,000 ways that don't work. www.rocko.rockcrawler.com
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    The rear axle is not a problem, the front you will need to grind the calipers and the backing plates. I am going with 4 1/8 backspacing on my 60 but you might be better off with 3 1/2 backspacing on a 44.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  3. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    why don't you go with 16" wheels...
    wheel's and tires are more expensive, but I found there isn't much of a selection in 15" 8 lug wheels...
    16" wheels are much stronger then the 16.5, and don't pop the bead as easily.
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>http://coloradok5.com/gallery/Jeffs-Stuff</a>
  4. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    15 x 10s w/ 4 1/8" backspacing (standard), yes, you'll have to grind the front, but not nearly as much as you do on a 60. Rear fits fine.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  5. rocko
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    I want to stay with 15x10.. so i don't have to buy new tires..
    I practically have brand new 35 bfg all-terrains..
    Tech 1 is the company.. But I find no listing for 15x10 8 lug wheels..
    Hope I find some..
  6. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    http://coloradok5.com/gallery/Daves-Pics
  7. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I bought a set of 15x10, 8-lug whitespokes from Summit Racing for $39.95 each plus basically free shipping. I believe the brand was U.S. Wheel, but I also think American Racing wheels offer the same thing.
  8. Emmettology 101
    May 9, 2000
    8,126
    FL
    Most places have them, but dont list them... Bart, ARE, etc. All have them.
    Mike
    <font color=green>"It's like a sore dick deal, You cant beat it!"</font color=green>
    <a target="_blank" href=http://www.geocities.com/emmettology101>www.geocities.com/emmettology101</a>
  9. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Im doing the same thing bro. Get the Bart wheels from Summit. You can get the white ones for around 40 bones, or you can get the chrome ones for 98 each. Shipping included to my door for 4 wheels was $412. I got the 3.5 backspacing. And like wayne said the rear clearance is not an issue. Only the front. I haven't started grinding yet, but will be soon. Good luck, PS, I know how you feel with the tires. MY BFG M/T's are like brand new.
    Learning to fry bacon!! [​IMG]
    3/4 in progress[​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  10. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    I'm in the process of my 3/4 ton swap right now. I ordered my 15x10 8 luggers from Summit. Came out to a little over $200 for 5 of them to my door. I sanded them last night and going to paint them black. I grinded my calipers this past weekend. It wasn't too bad, just make sure you wear a respirator and some hearing protection. I followed the method Rene suggested. Paint the caliper and fit the wheel on to see where it rubs the paint off. Worked great! Oh and I remembered to do it before I mounted the tire. Thanks man! I'm almost ready for the swap... good thing to, I just blew my 10 bolt yesterday!
    Rod
    Alameda, CA
    85 K5 6"ProComp 35"Boggers... and it's still not BIG ENOUGH!!
    <a target="_blank" href=http://coloradok5.com/gallery/K5Jungle>http://coloradok5.com/gallery/K5Jungle</a>
  11. rocko
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Savage.. did you get a part number for your wheels?
    If so.. may i get it from you.. I'd like to order them today and hopefully have them by the weekend..
    Appreciate everyone's input..
    So.. standard backspacing is what I should go for?
  12. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    If you dont mind grinding more. With the 3.5 you wont have to grind as much, but it will make your wheels stick out a "tad" further!
    Just say no to crack(s)
  13. SAVAGE1
    May 22, 2000
    1,104
    BAY AREA, CA
    Rocko, here is the part # from my invoice: USW-70-5080
    This should take you directly there:
  14. rocko
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Thanks Guys.. and especially Savage..
    I'm going today to order them.. Axle swap is getting closer.. [​IMG]
    And does anyone know the size u-bolt's I need for the 14 bolt rear? inner diameter?
