wheel question
Discussion in 'The Garage' started by 1982blazer, Apr 13, 2007.
  1. 1982blazer
    1982blazer 1/2 ton status
    May 11, 2006
    313
    Tyler Texas
    Quick wheel questoin and i have already searched. I am about to order wheels for my 3/4 ton conversion i am going to run 15's cause i have good 15 inch tires. I was looking on national wheel and tire, at the eaton 15" steel wheels and it says 3.5" back spacing for minimal caliper grinding, but wouldn't i be able to grind lest with 2.5" back spacing. I just wanted to clear this up before i order. thanks for the info fellas.:bow:http://www.ntwonline.com/acb/showdetl.cfm?&DID=48&Product_ID=2202&CATID=11
    Edit: i will probly buy procomp extreme rockcrawler steel wheels.
  2. barneybasher1010
    barneybasher1010 1/2 ton status
    Sep 25, 2005
    908
    PORTERVILLE CA
  3. 1982blazer
    May 11, 2006
    313
    Tyler Texas
    Alright thanks thats all i needed to know.:bow::bow::bow::bow::bow::bow:
  4. goldwing2000
    goldwing2000 Guest
    Ditto. I'm running the exact same wheel (15x10) and even paid the same price.
    It gets the side of the truck hella dirty but it's good enough until the tires wear out and I get some 16.5s
  5. 1982blazer
    May 11, 2006
    313
    Tyler Texas
    I ordered the 15x8 because it was cheeper and these will do for now. Some day i want to run some hummer h1's.
  6. barneybasher1010
    Sep 25, 2005
    908
    PORTERVILLE CA
    I got the 15x8 because I wanted a bead lock effect. I had 15x10 and popped the tire off the bead at low pressure(about 8 psi), now it is not a problem.
  7. goldwing2000
    goldwing2000 Guest
    Narrower is definitely better if you're running low pressure. I never do, so I'm more concerned about even wear across the tread.
    Plus deeper wheels look better. :D
  8. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    and my bro Tim let his steel 15 x 12 Barts go.:doah: "but the kid said he would bring the rims back?':haha:
