wheel shimmy
Discussion in 'The Garage' started by Jonny-K5, Aug 4, 2004.
  1. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    i've been trying to figure this out for awhile, it seems to be getting a little worse. it happens when im braking and one wheel hits something, like a pothole or bump in the road. it also happens when i drive over R/R tracks, but only when the brakes are applied. usually around 30-40 mph.
    i just came back from camping in the mountains and the wheel would really wobble when going downhill and slowing down for switchbacks.
    i've stuck my head out when it happening and the front wheel is shaking pretty bad.
    wheel bearings are tight, balljoints look good, as do tie rod ends and drag link. what could be causing this? oh ya there is a pretty big dent in the steering stabilizer, coild that do it? i thought maybe rotors are warped but my friend said that would be more in the brake pedal.
    BTW i checked the tie rods by shaking it, and i checked ball joints and bearings by wiggling the wheel while a friend looks for play. is there a better method?
  2. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    anyone? any ideas would help, im kinda stumped.
  3. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    The rotors on my daily driver have over 180,000 miles on them and have never been turned. They have never been turned and are warped VERY bad. I can't feel anything at all in the pedal, just the steering wheel and the whole truck shakes some.
    To check the bearings I jack the truck up and grab the tire at the top and bottom and push/pull in/out. To check the draglink and tie rod I have someone turn the steering wheel (with the truck on the ground) and watch for loose parts.
  4. eightyone
    eightyone 1/2 ton status
    Apr 25, 2004
    292
    long island
    i would say check to see if your wheel is balanced /forums/images/graemlins/dunno.gif
  5. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    Jack the front end up, and use a pry bar under the tire to lift it while looking at the ball joints...
    have some one move the steering wheel back and forth while watching the tie rod ends....
    Idler arm is another potential culprit...
    my vote goes to a bad tie rod ...easy fix...
