Wheel size for a newb
Discussion in 'The Garage' started by dbozman, Jan 15, 2007.
  1. dbozman
    dbozman 1/2 ton status
    Nov 11, 2006
    115
    Phoenix
    New '74 K5, D44 and 12-bolt stock. Will be running 35 MT/Rs and need new 6-lug wheels. The truck had 33 on chrome steelies, which I've since sold. Based on the appearance of the tires on the wheels, I took them for 15x10 wheels.
    Are most people running 8 or 10-inch rims?
    The wheels had 3 5/8 inches of backspacing, which seemed very tight in the front. I was looking to get the tires moved out a bit to better fill the wheelwells (ie. a 3-inch BS or so).
    Problem is you can't get that BS unless you go custom, which I don't want to do.
    Thoughts?
    What wheel size are you guys choosing that offer plenty of steering clearance, but fills the wheelwells nicely to the outside. Any resources to buy these wheels?
    Here's a photo of the former wheel to illustrate. Remember, I'll be replacing the 33s shown with 35s.
    Thanks.
  2. filo
    filo Registered Member
    Mar 11, 2006
    96
    Anoka, Minnesota
    Have you tried searching around here?
    There are thousands of questions and answers here. :bow: :bow: I'm sure that has been asked or discussed before.
    I haven't found a topic that hasn't already been addressed yet.:bow:
    The only problem might be the time to find it. :doah:
    good luck, dude. :waytogo:
  3. filo
    Mar 11, 2006
    96
    Anoka, Minnesota
    Sorry, I should have started with.......nice truck!!
  4. dbozman
    Nov 11, 2006
    115
    Phoenix
    Of course I've searched. The problem then involves too much information rather than not enough. Or perhaps my search terms weren't tight enough. If someone wouldn't mind providing some guidance I'd appreciate it. Thanks.
    d
  5. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,852
    280
    Truckee, CA
    Rim width shoudl be based on tire width. If you are sticking to the appearance that you had, im guessing your going wiht a narrowish 35, in which case a 8" wide rim woudl be my solution.
  6. sope
    sope 1/2 ton status
    Jul 8, 2005
    967
    British Columbia
    It depends on tire width and what your using it for. For example if your running 12.5's on the street mostly and limited trail I would go with a 10 " rim for better tire wear and stability. If your wheelin a lot and airing down , I would go with an 8" rim to help keep from breaking the bead and it's easier to re set the bead on the trail.
    You haven't said what width your 35's will be though.
  7. TexasBlazerBoy
    TexasBlazerBoy 1/2 ton status
    Oct 10, 2005
    1,674
    North Texas
    :D Sweet truck:D I love that paint scheme:bow:
  8. dbozman
    Nov 11, 2006
    115
    Phoenix
    As I said, they're 35 MT/Rs, which means they're 12.5 (sorry for the assumption that you guys would have that info).
    I've been four-wheeling and rockcrawling for years. I understand tire to rim ratios. My real question, being a first-time K5 owner, is how different wheeld widths affect the appearance of the truck. I can't quite tell if my old wheels were 8s or 10s. Assuming they were 10s based on the flat tire profile.
    Just trying to save myself some experimentation money and buy the right wheels the first time.
    d
    PS: Do you really like the color. Man, I was planning a repaint ... :D
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    15x10's aren't bead friendly aired down , and frankly they look like lowrider tires that way . 15x8 holds a bead better , looks better , and if you air them up based on actual vehicle weight instead of the max air pressure on the sidewall , they wear fine .
  10. TexasBlazerBoy
    Oct 10, 2005
    1,674
    North Texas
    Heck no don' t dare repaint(in my opinion) that is classic. You've got the full top removal thing going on also. Like I said sweet ride.:bow: What are your plans, DD, mud, rock everything in between?
  11. dbozman
    Nov 11, 2006
    115
    Phoenix
    Well, it appears I got a decent deal on some 15x10s locally, so I'll give that a try. I've run this tire size on both 8- and 10-inch rims and didn't notice much difference.
    Plans? Well, I'm done with rockcrawling. This truck will be a "fun rig." I'll drive it when I feel like. Plan on rebuilding the interior, tweaking some stuff here and there and having a fun-to-drive street rig.
    d
  12. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    sounds to me like u already knew what u wanted, i personnaly think there is a lot of difference. i like my 35 mtr's on 15x7" wheels.
