wheel size?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by punchdrunk, Oct 11, 2001.
  1. punchdrunk
    punchdrunk Registered Member
    Jul 7, 2001
    33
    santa cruz, ca
    in your opinions what is the best rim size for 35" m/t's ?
  2. dragricinMT
    dragricinMT 1/2 ton status
    Jul 21, 2001
    135
    Billings Montana
    How wide of a 35"? I'm running 35x12.5x15's on 15x8.5 wheels. This way the wheel rim is in farther for a little more protection.
    78-K5 4"Lift 35"Tires 400SB TH350 NP205
    73 Vega 350SB TH350
  3. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I run 9" wide wheels with my 35x12.50r15 MTRs. This keeps the bead protected.
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  4. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I got 35x14.50's on 15x10's.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Do us all a favor, brother, and fill in your profile. [​IMG]
    <font color=blue> NEVER FORGET, NEVER FORGIVE, NEVER SURRENDER<font color=blue>
  6. punchdrunk
    Jul 7, 2001
    33
    santa cruz, ca
    done,forgot i had not filled it in,i also didnt mention i'm running 8 lugs so 15"s are not an option ,correct?
    <P ID="edit"><FONT class="small">Edited by punchdrunk on 10/12/01 09:53 AM.</FONT></P>
  7. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    There are a ton of 15 inch wheels for 8 lugs.
    74 Blazer
    Zepplin
    Check out my Blazer<a target="_blank" href=http://community.webshots.com/user/zepplin1976>http://community.webshots.com/user/zepplin1976</a>
  8. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I got 8 lug 15" rims on my Jimmy. Steel rims would be the only option if you want to stick with the 15" size and you will have to grind your front calipers a little or a lot depending on your backspacing and what front end you have (D 60 or D44, 10 bolt)
    I have my 36" x 12.5" TSL's on 15 x 10's...I'd prefer to have em on 8's but I got a smokin deal on the 10's.
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  9. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I run my 35x12.50s on 15x10s. While a narrower rim would keep the bead further inside the protection of the tire, it also puts more sideways stress on the bead. My sidewall in straight in-line (somewhat) with my bead. This reduces the stress on it as the tire shifts. I also like how well the tread pattern lays down with 10" wide rims with very little air down. A friend of mine had to air his 35x12.50s down to 8 PSI to get the same tread impact as I did by only airing mine down to 18. But, wider rims also make fender clearance an issue upon cornering.
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  10. punchdrunk
    Jul 7, 2001
    33
    santa cruz, ca
    I should have said I have a d60 up front with a 14ff in the rear,is there a big advantage to go with 15'' rather than 16'' or even 16.5''i heard theres alot of grinding for a 15'' on a d60
  11. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    I would think you would want to go with a 16" or 16.5". Between those, I don't know which has more tires available. The 16" tires usually have a higher load rating. With a D60 and such, you will probably want that.
    Brian
  12. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    16.5" rims have no saftey bead so running lower air pressures off road means you'll prolly lose the tire off the rim. 16's have the safety bead, but the availabilty of sizes is still limited. 15's have the lip and the largest selection of tire sizes.
    If you aren't going over 35" I would consider 16" rims. If you want bigger than 38" anytime soon I'd go 15" and grind...
    Rene
  13. punchdrunk
    Jul 7, 2001
    33
    santa cruz, ca
    does anyone have pics of the amount of grinding required?
