Wheel size
Discussion in 'Pacific Region' started by clubba68, Dec 16, 2003.
  1. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    OK, I am about to order wheels (present from my parents for Christmas), and I just need some input. I am going to go with either 15x10 or 15x8. I am going to be running some 35x15x15 SSR's to begin with, and probably moving down to some BFG 35x12.50x15's after that or something comparable, although I may decide that I really like the SSR's and buy another set when these are toast. So, 15x10 or 15x8? Also, how much backspacing? I am going to be running 14bff rear and D44 8 lug up front w/ 4 wheel disc, but I want to purchase wheels with backspacing that will work with a D60 because I will inevitably step up to one sooner or later, and I don't want to have to go out and buy new wheels then. I would like to just shave the calipers down on it and keep the same wheels.
    15x10 with what backspacing?
    OR
    15x8 with what backspacing?
    OR
    Ideas of your own? (Besides 15x2 Shannon) /forums/images/graemlins/thumb.gif
    Thanks,
    Andrew /forums/images/graemlins/usaflag.gif
  2. 4xrick
    4xrick 1/2 ton status
    Sep 14, 2003
    1,102
    kirkland Wa
    if you are running 15x15 i would go 15x10 not sure about the backspacing though
    i dont even know what mine are but when i was runng 14.5s i hadjust a little rub when flexin
  3. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    yeah, got 15x10 especially if there is even the chance that you might run bigger tires later on.
    AFA backspacing goes I'd recommend 3-3.5" of bs. From what I understand really small backspacing (like 2.5") can be tough on your bearings... and big bs like 4.25" will require you to grind a lot of material off your calipers (been there, done that!). something in the low-to-mid 3 range seems to be a good compromise.
    j
  4. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    15x10...3-3.5" of bs
    Yup. Them's the right numbers! /forums/images/graemlins/thumb.gif
