Wheel Spacer Question...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Jeff427, May 30, 2000.
  1. Jeff427
    Jeff427 1/2 ton status
    May 22, 2000
    1,186
    Gladwin, MI
    I'm planning on running 1.5" spacers on the back of my '78 Blazer to even up the front and rear width. Has anyone had any problems with spacers in the rear? The people at the local garage tell me not to run spacers because they aren't safe. Thanks.
    Jeff427
  2. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    The people at the garage you talked to probably are thinking of a different type of wheel spacer. Just a slab of metal that goes in between the wheel and brake drum. Those are kind of crappy. The flex and move and stuff...bad things can happen. The 1.5 inch adapters you want actually bolt to the axle, then your wheel will bolt to those. They are tons better than the first ones I mentioned. I think they are billet too.
    '73 K5
    Chevy good...Ford bad
  3. Hayduke
    Hayduke 1/2 ton status
    May 9, 2000
    271
    NE Columbus, Ohio
    look under "product reviews" on this site, there's a good write-up and lots of helpful info...
    HAYDUKE
  4. Jeff427
    May 22, 2000
    1,186
    Gladwin, MI
    I saw the review of the spacers on this web site. Actually I am thinking of making my own spacers out of steel (I work in a machine shop) and getting longer studs so the studs go thru the axle, brake drum, spacer, and the wheel. It seems to me like it would be stronger this way. I can get longer studs that are stronger than grade 8 from Moroso, and they are long enough to fit.
    Jeff427
  5. K5Junkie
    K5Junkie 1/2 ton status
    Mar 29, 2000
    499
    Gulfport, MS
    I have been running the same spacers that are in the product review for about 5 months now. I have had no problems with them at all. it make the blazer look alot better now that the tires line up.
  6. NJ SAR Guy
    NJ SAR Guy Registered Member
    55
    New Jersey, soon Florida
    As far as everything I've heard, they work great.
    Just two things to consider:
    1) Check local laws. I know they are illegal in New Jersey.
    2) I believe GM gave the Blazer a diffrent axle width in the rear for better traction off-road. If you're into wheeling, depending on the type you do, you may want to keep the diffrent width.
    NJ SAR Guy
    Please excuse all of my misspelled wurds.
  7. dumbfounded
    dumbfounded 1/2 ton status
    May 20, 2000
    176
    Castalia, NC
    There will be added stress to your bearings/axle but this is easily fixed with rim backspacing. If you could imagine once you place them on the rims are no longer trying to push up they are trying to "bend" a little at the axle b/c they are no longer just pushing up. The center of the rim should be at the axle or different stresses will incur. Unless you carry heavy loads or hit things really hard I wouldn't worry. If the spacers bolt to the drum and the wheel to the spacer the axle would snap long before the spacer would fail....
    Wasn't me.............
  8. Jeff427
    May 22, 2000
    1,186
    Gladwin, MI
    I am building my Blazer primarily for wheeling, I'm even leaving it full time. Here are the soon to be specs;
    78 Blazer
    Full time 4x4 (203)
    TH 350 trans (TransGo shift kit, high torque towing torque converter)
    Shakle flip with 2" add a leafs in the back, 4" springs in the front
    3.73 gears front and rear (12 bolt with spacers, Dana 44)
    '71 472ci Cadillac (stock, 500ft-lbs@2800rpm)
    Jeff427
  9. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    Just my opinion, but I wouldn't take the chance on making my own spacers. If it's a slow-speed trail machine, then maybe but if it'll see road time, I'd go with proven safety. Especially since their only 65-85 buck each.
    Small price for safety in my opinion.
    Brian
  10. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I run 1.5" spacers (the same as in the product reviews) and have had no problems as of yet. The narrower rear axle on the Blazer and other GM trucks was meant to help handling (turning) as a narrower rear axle helps keep the front end from "pushing" in corners (when you turn the front tires, they will slide and the vehicle will continue to go straight). Before I installed the spacers, the back of my Blazer would slide all over the place in mud and ruts when trailriding. Once the spacers were installed, I really noticed a difference off-road concerning the vehicle tracking straighter.
  11. Jeff427
    May 22, 2000
    1,186
    Gladwin, MI
    I guess what it boils down to is, should I use six studs all the way through the spacer or should I use twelve studs (six hold on the spacer, six hold on the wheel [like the ones in the review on this web site])?
