Wheel spacers.. Up front???
Discussion in 'The Garage' started by 78Suburban, May 11, 2006.
Can I run 1" wheel spacers on the front of my 3/4 ton corp 10?
  1. yes, you can and they won't break, even if you wheel it HARD
    11 vote(s)
    31.4%
  2. Don't do it, you'll break and go crashing to your death
    8 vote(s)
    22.9%
  3. I have no useful opinion, but I'm very NEKKID!
    16 vote(s)
    45.7%
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    I have a BONE STOCK burb, with 33x12.50x16.5" tires on stock 16.5x6.75" wheels. I've done all the appropriate fender trimming, but the inside of the tire is rubbing on the end of the pitman arm/ drag link when I turn hard to the right. Would it be safe to run 1" wheel spacers up front? Are my wheels gonna break off and I go flying into a tree? I would run them on the rear 14ff in a minute, but I'm just a little more hesitant on the front axle.
    Before someone brings it up, I know it'll wear BJ's and bearings more than stock, but so would the offset wheels I would need to properly clear the draglink. So that's not a concern.
    So should I run some 1"ers up front? Any really durable brand someone wants to recommend? Its 8 lug and has drive flanges, btw..
    thanks,
    James
  2. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    i'm running 1.5's up front and will be moving them to the rear and doing 3's up front then to make em match again.
  4. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    where can I get 1" spacers with 9/16" lugs for cheap?
    thanks,
    James
  5. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    the for sale forum here if ya can. I bought mine new off of ebay. about $100
  6. norville
    norville 1/2 ton status
    Dec 27, 2005
    268
    A stones throw from Pargon Mountaintop Pa
    Option #3. I would think i'd be about the same price for offset wheels?
    bob
  7. paintyouup123
    paintyouup123 Registered Member
    May 31, 2005
    14
    California
    Make Shure that you Check for excessive heat. I have used them before and the hubs got pretty darn hot.
  8. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    Why is it that the stores on ebay sell the spacers with 14mm lugs for 80 bucks, but the spacers with 9/16" lugs are 130 bucks? I really just want a set of spacers that are 1" and have 9/16" lugs, so I can bolt them right up to the front, and use my old nuts.
  9. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    Obviously, If I were to get a new wheel, I need one with less backspacing. Just how much backspacing do the stock 16.5x6.75" wheels have?
  10. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    You're the one with the wheels...:deal:
  11. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    rotflmao
  12. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    OWNED!!!!
  13. broc944
    broc944 1/2 ton status
    Sep 23, 2005
    1,660
    Northern Minnesota
    X 2
  14. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    :doah:
    Guess I need to get off my lazy butt and break out the pull handle, floor jack, and tape measurer. I was just wondering if somebody had the specs in their memory.
    I can't find any narrow 16.5" wheels that don't have tons of backspacing on them.. So I still think I'm going to go with some wheel spacers, if I can ever find some at a decent price, and that aren't 14mm.
  15. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    why keep the narrow rim? ive ran 10" wides with 33's and they were great.
  16. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    16.5's have no safety bead. The stock ones have a very small "safety bead", and narrow wheels are a poor man's beadlock. I feel confident that with 10" wide wheels, I will blow a bead. I'm thinking on being a cheap bastard, and just adjusting the steering bumpstop on the knuckle, which will kill my turning radius. :doah:
  17. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    why not go this route if you are a cheap bastard?
  18. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    you dont want tons of backspacing...you want minimal backspacing. the more backspacing and the more the itr will be under the truck...less backspacing and the more they stick out.
  19. 79k20350
    Nov 22, 2004
    7,757
    Ct
    DOH!:doah: i should read closer huh...you said that DONT have tons of backspacing....Oh well...back to the lounge for me...!:haha:
  20. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    anybody have a link to 1" spacers with 9/16 studs and lug nuts included? I'll order them right now if I can get a link, but I havent found any.
    Thanks,
    James
