wheel spacers
Discussion in 'The Garage' started by Jonny-K5, Mar 18, 2004.
  1. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    i've got 3" long wheel studs in my rear axles and i was thinking of putting some wheel spacers in there to bump the rear tires out a little more to match up with the front. plus i wouldnt have so much stud sticking out past the nut.
    i know they make ones that bolt on, but what about one that slides onto the studs and sandwiches inbetween. are these a good idea? it seems like they would be safer then the bolt on.
    i've seen them in summit before, but only 7/16 thick and only a 5 lug pattern. anyone know where i can get a 6 lug 1" thick version?
  2. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Not sure how safe that would be. /forums/images/graemlins/thinking.gif IMO it'd be too much stress on the studs with the spacer and wheel being two separate pieces. I'd do a BUNCH more research before you did that.
  3. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    wouldnt it just be like having an extra thick wheel? anyone else done this? on second thought,maybe it would be too much stress , any more opinions?
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I think wheel spacers are a bad idea, no matter what style they are, but that is my personal opinion, and many here run them sucessfully.
    The main problem with a 1" thick spacer that just slides on is the shear loads. I would think that unless you used some super strong wheel studs, you could easily shear off all of the studs and lose a tire that way.
    The bolt on ones use the cone shaped inner lug nut to center the spacer on the stud, and help distribute the shear loads better IMO.
    I'm no engineer, although I aspire to be one some day, but it just doesn't seem like a good idea IMO.
  5. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    I dont know if I would run them permantely, I am running the 8 to 6 lug adapters that are 1.5 inch thick only because Im waiting to install my dana 60 and go all 8 lug. I dont plan on having them on there very long and I plan on constantly having to check the torque on the spacers. It's critical to keep a close check of the torque of the spacers for the first few miles because they are aluminum. And if you go to www.truckinsuspension.com they got just about every wheel spacer/adapter you can imagine. And I believe they will do custom applications.
  6. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    i figured as much. thanks for the input fellas
  7. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
