Wheel spacers?
Discussion in 'The Garage' started by cbbr, Dec 14, 2004.
  1. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Front wheels rub on th steering when I tun and hit a bump. Not good for offroad.:doah: The wheels are Hummer H2 wheels. They fit/look god otherwise(and were cheap).
    Would spacers help? Can I use large washers or do I need actual spacers? Is there a disadvantage to using spacers?
  2. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    295
    Truckee, CA
    washers sound like a bad idea to me......seems they would cause your lugs to loosen over time......
  3. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    If anything you buy spacers made for your vehicle unless you can have them professional manufactured. Typically spacers aren't recommended and aren't considered a viable solution for anything.
  4. cbbr
    Jul 17, 2004
    14,681
    What is the disadvantage?
  5. Big Red
    Big Red 1/2 ton status
    Jan 9, 2003
    250
    Bristol, CT
    aside form adding undue stress to your wheel bearings...
  6. cbbr
    Jul 17, 2004
    14,681
    I really think that 1/2" will do - should not be too much added stress. Besides the added stress, are there any safty concerns?
  7. Big Red
    Jan 9, 2003
    250
    Bristol, CT
    well then, if its only a half inch, it shouldn't be a problem. i don't think you'll have too much trouble with the lugs loosening. just be sure to torque them down to spec and you should be fine. o, btw, check the length of your studs. you're probably gonna have to get longer ones. good luck!
  8. BURBicon
    BURBicon Registered Member
    Dec 11, 2004
    78
    Sunny Phoenix
    spacers????
    Are you sure you need them?? I would drive onto something that would normally make the front wheels bump, then stop and get out and see what is hitting. This may save you some time/money/frustration.
  9. cbbr
    Jul 17, 2004
    14,681
    Ya think? Maybe I should let you talk to my "mechanic" who suggested ripping off the mudflaps with the metal wire crap. No spacers needed.:xmas:
  10. BURBicon
    Dec 11, 2004
    78
    Sunny Phoenix
    spacers??
    Dude..... don't get all "butt hurt". I was just givin' u a hard time.
  11. cbbr
    Jul 17, 2004
    14,681
    Just happy that I didn't spend a ton of money on another FNG prob.
