wheel spacers
Discussion in 'The Garage' started by digity, May 7, 2005.
  1. digity
    digity 1/2 ton status
    Oct 10, 2004
    184
    13
    Brentwood Ca
    It's to my understanding that the rear axle is 3" shorter than the front axle. Is anyone using spacers in rear to correct this. Also, are there pros n cons in doing this. I'm asking cause getting ready to do 3/4axle swap soon. Thx for any info on this. :cool1:
  2. 4wheelin4Jesus
    4wheelin4Jesus 1/2 ton status
    Mar 20, 2005
    149
    north carolina
    check this link out if you havent already.
    http://www.coloradok5.com/wheelspacers.shtml
    Ive talked with the tecs at performance, and they say they have never had one break yet. They said that it has the same properties as a deep dish wheel. But, if you are thinking of doing the axle swap, go with the 1 ton. The 3/4 ton is really just a beefed up 1/2 ton.
    God Bless.
  3. digity
    Oct 10, 2004
    184
    13
    Brentwood Ca
    Excuse the rookie question but how excatly does the application work.
  4. 4wheelin4Jesus
    Mar 20, 2005
    149
    north carolina
    Its pretty basic. You said your axles are 3" shorter than the front. Take the 1 1/2" spacers, and put them over your wheel studs on your axle. The kit should come stud nuts. Tighten them down to the correct torque, and you are ready to go. Put your wheels back on, and you now have an axle that is 3" longer.
