wheel spacers...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90blzr, Jul 26, 2001.
  1. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    Who has the best price on the wheel spacers for the rear? And what size, I think its 1.5" to make the rear wheels even with the fronts, but not sure. Thanks
    <P ID="edit"><FONT class="small">Edited by 90blzr on 07/26/01 01:04 PM.</FONT></P>
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Performancewheel.com has them for 65 each. I ordered the 1.5's and they sent me 2". SO I tried them on before I sent them back and they look perfect. But you should measure your truck to get an acurate number
    Did you say I have monkeys flying outta my butt?[​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  3. DERBINATOR
    DERBINATOR 1/2 ton status
    Jan 26, 2001
    196
    YANKTON,SD
    What do you need? 6 or 8 bolt. If you need 6 bolt I have a set that I want to sell. If your interested I have some pictures I can e-mail you.
  4. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    I have the 1.5" by performance. It looks perfect. But Steve said 1 1/4" is right....who knows.....
    Boss
    89' 1 TON of FUN K5
  5. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Performance wheel and tire 1.5". They sent mine with acorn nuts (.75 a piece). When I put on the acorn nuts, they stuck out about 1/4" and the tire wouldn't sit flush. Just go down and get some 7/16 lug nuts. On the 12-bolt the 1.5 is just right and you won't have to trim the stud.
  6. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    74
    Humboldt/Pacifica, CA
    Correct me if I'm wrong, but isn't the reason the front wheels stick out more is for better traction off-road. And don't spacers have a negative effect on the load put on the bearings?
  7. 88streetblaze
    88streetblaze 1/2 ton status
    Jun 27, 2001
    314
    middle of sticks, oklahoma
    spacers can have a negative effect on the bearings if you abuse the rear end otherwise it is negligable. and i've always heard that they spaced the tires like that for traction but i read some where that the main reason was that by doing that they point more understeer in it and that improved trailering.
  8. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    If you use a 1ton VAN 14FF it will be about 3" wider than a truck rear end. That works out to 1.5" per side which will make it about the same width as the front.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
  9. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    hey, I need a set (both 6 bolt and 8 bolt) of the good high grade allum. send me a pm with what ya got and a price.
    [​IMG] <font color=blue> Jeff </font color=blue> [​IMG]
  10. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    Nope, I need 8 lug, thanks for the offer though.
  11. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Go with the van rear ends- 12 bolt or 14 bolt.
    I'm welding my new, custom spring perches (sp) on my van 14 bolt this weekend. You get a wider axle without any drawbacks of the spacers.
    thebigdaddyof2
  12. Stephen
    Sep 15, 2000
    4,228
    142
    Carbondale Colorado
    My 12 bolt van was 4" wider than stock. I had a half inch spacer for the front, then went with 1" spacers on each rear and a 1 1/2" on the front for a total of 6" wider than stock and it worked really well. Puts the tires about 1-2" outside the fender, perfect for keeping it off rocks while still looking ok for the street.
    Making the world better, one truck at a time.
    SW-ORD
  13. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    I was under the impression that the rear is narrower to get it to have a tighter turning radius and to make it track better going down the road. After installing a locker in the front you cant turn it anyway, so then that is all out the window.
    I thought I was wrong once,
    but I was mistaken
  14. 1990K5
    1990K5 1/2 ton status
    Nov 6, 2000
    460
    LITTLETON CO.
    bought mine at performance for 100/pair
  15. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Do you still have the spacers for sell? How much ? How much to send to AZ?
    C'moe
    <font color=black>the blazer is "Back in Black"
  16. DERBINATOR
    Jan 26, 2001
    196
    YANKTON,SD
    I'm thinking somewhere around $100 (obo) includes shipping. Like I said earlier I can e-mail pictures. These are 1.75" thick made from 6061 t6 alum.
