Wheel spacers
Discussion in 'OffRoad Design' started by TK5, Apr 13, 2003.
  1. TK5
    TK5 1/2 ton status
    May 29, 2002
    319
    Fairview , Tennessee
    I wanting to add a spacer on the rear of my 14 bolt, but I don't want to with the lug to lug route.
    What I would like to have is a spacer that goes between the hub and rim with longer studs. Is this possible?
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    You mean replace your stock lugs with longer ones and just use a simple spacer? Or you mean the kind that most use where you just bolt the spacer to the stock lugs and the the spacer has its own lugs on it. I would be scared to run lugs that long myself, can you say twisty? Be like blocks, puting a lot of torque on those things. My friend broke 4 studs off on his 383 Chevelle. Especially if your a crawler or something with lots of quick torque bursts.
  3. Greg72
    Mar 5, 2001
    15,682
    1,392
    642 Days to BB2018
    Sled Dog's got it right.....I wouldn't want wheel studs that long....you're asking for a catastrophy!!
    The kit that everyone around here uses (AFAIK Watson, Fox, etc) uses standard studs to attach the spacer and another set to hold the wheel. I've used this setup and it works fine. I'm sure your concern is having to pull the wheels to recheck torque, but I can tell you mine have ALWAYS stayed tight. I didn't even retorque after 100 miles like you're supposed to.....!!
  4. burban33
    burban33 Registered Member
    May 2, 2002
    33
    Georgia
    I think he is talking about spacing the whole hub outward instead of using a wheel spacer, like moving the entire rotor and lug section for more width
  5. TK5
    TK5 1/2 ton status
    May 29, 2002
    319
    I have put disc brakes on my 14 bolt. Of course it has 8 lugs, 9/16" studs grade 8. This has more strength that a chevy 5 or 6 lug which only use 7/16"s studs.
    I am wanting just to install a 1" plate on the hub with longer studs then the wheel. Seems to me I would rather have 8 lugs and nuts to worry about as opposed to having 16 studs and nuts to worry. I may be wrong!!! That's the reason to ask.
    Maybe I should mention this is on '83 Chevy K5 with a 6.2 with 4.10 gears. I don't do much rock crawling, some trails, most daily driving and Search & Rescue for emergency services.
  6. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    That is a very interesting idea and sounds like it would work to me. Where can you find the studs that are 1" longer than stock and where can you find a spacer?
  7. TK5
    TK5 1/2 ton status
    May 29, 2002
    319
    I found the studs at the local auto parts store. The spacer can be the same spacer that every one is using with the exception of the extra studs just 8 holes for the studs on the wheel.
  8. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    There is a review here on ck5 and it has a link to the place they bought thier spacers.
    There is a member here who makes them out of 6061-T6 and that is where I got mine. You can find him at Echobit.com]
  9. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    my spacers are the "16 stud" variety and I have very few problems. I do check them periodically (about once a year) and I have one stud in the alum. that's a bit loose now but it still tightens up just fine so it's not really a problem. They've been on there for several years so far, I think back to '98 maybe?
