Wheel Spacers
Discussion in 'The Garage' started by georgesmith, Feb 10, 2004.
  1. georgesmith
    georgesmith Registered Member
    Feb 10, 2004
    5
    I'm new and have a question. I want to make my rear wheels wider and I see this on Ebay:
    Chevy Blazer or Truck Wheel Spacers Item number: 2459386777
    Will these work and are they recommended?
    Thank you,
    George
  2. georgesmith
    Feb 10, 2004
    5
    39 people looked and nobody replies? I guess I won't bid on these things since they are not worth commenting on. Are there any better spacers I can purchase from a vendor? Any suggestions? I would like to make my rear track wider.
    Thanks in advance for a reply.
    George.
  3. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Who is the manufacturer?
  4. georgesmith
    Feb 10, 2004
    5
    It doesn't say. I will see if I can find out from the seller.
  5. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Not knowing who makes the ones you are looking at, or what width, etc., I can only comment in general. I've been running Performance Wheel spacers for about 3 years now, with no issues on 14 bolt rearends. /forums/images/graemlins/laugh.gif
  6. georgesmith
    Feb 10, 2004
    5
  7. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    If you want to make the rear the same width as the front you only need a 1.5" per side spacer... Performance Wheel does make some good spacers.
  8. kw48653
    kw48653 Registered Member
    Sep 16, 2003
    86
  9. 85m1009
    85m1009 1/2 ton status
    Jul 11, 2000
    718
    Missouri
    Just and FYI for those interested. I recently purchased a set of Hub centric 3 1/2" steel spacers for my Hummer wheel upgrade from Arrowcraft. These things are a work of spacer art. They even have 5/8" wheel studs instead of 9/16". The only drawback is that they are heavy. They are as cheap or cheaper than the aluminum Performance spacers depending on size. Again just food for thought. /forums/images/graemlins/thinking.gif
  10. georgesmith
    Feb 10, 2004
    5
    The guy just emailed me and said he measured the spacers and they are 1-1/2" wide each. Go figure.
