Wheel spacers
Discussion in 'The Garage' started by Mastiff, Feb 28, 2004.
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I know this must have been covered, but I can't seem to get search to find a single match for "wheel+spacers". /forums/images/graemlins/confused.gif
    I was thinking about spacing out the rear wheels a little to match the width of the front. It would just be for looks. Is the concensus that there is really no downside to this in terms of strength/reliability? There would certainly be a little more leverage on the axles, but maybe it's not enough to matter. I have a 12b rear if it matters.
    A few other Q's: How much spacing do I need to get the rear and front to be the same track? Anyone have any before/after pics? Right now I have no cap or anything to fill the center hole in the rim. The factory one rusted away a long time ago, but it doesn't much matter if I just keep the drum painted. It'll look weird though with the spacer I think. Any suggestions for center caps or something?
    Thanks!
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    You need 1.5" spacers(each side) to equal the front. I don't run them personally but from what I've heard as long as there not real wide then it won't be a problem...1.5" would be fine....
  3. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    TONYP here makes some. You can check the ORD site has some various WMS widths listed.
  4. santana
    santana 1/2 ton status
    Jan 11, 2003
    1,483
    Mesa Arizona
    I run 1.5 spacers on mine with 12" wheels, been running them for over 5 years and no problems as of yet, just have to keep 'em torqued..
    pic
  5. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I talked to a old motor head and was told that the 14FF is such a strong axle and for a 1ton truck that running spacers will not hurt anthing on the axle...
