wheel specs..
Discussion in 'The Garage' started by XHitman396, Jul 7, 2006.
  1. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    so what are the specs for a 14bff as far as wheels go?? its an 8X6.50 in bolt pattern i think. but what size center hole for the front hub of my 10bolt?? would 5.15" be the one?? smaller/larger?? and what is the backspacing necessary?? hell, here are the wheels im looking at: http://store.summitracing.com/partdetail.asp?autofilter=1&part=CRR2D3425880&N=4294923107+4294923106+400292+1003+115&autoview=sku
    will they work on a 14bff and 10 bolt front (converted to 8 lug)?? thanks for your help...
    oh yeah, and what's the O'Reilly's part number for a u-joint to go from a stock '87 k5 drivetrain to a 14bff??? thanks again.
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,010
    7
    Binghamton NY
    Only two diff types of 8 lug that i know of, 8x6.5, standard for who knows how long, on 3/4 and 1 tons to current trucks, and then the Stupiduty are metric, 8x170 mil. I don't think there is too much of an option on hubs openins on aftermarket rims. Usually one size fits all type of deal. B/S depends on what size of wheel, and if you want the wheel to stick out or in at all. I have a set of 8s on my truck that are 4" B/S, have a set of 12s on my other truck that are 3.75 B/S. The 8s don't stick out too much, while the 12s stick out a whole lot. Slings some mud......
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Your link does not go anywhere. The wheels are lug centric so it does not matter if the center hole is too large as the lug nuts center the wheel. A center of 5.15 will def fit on a 10 bolt. My Dana 60 hub is about 4" in diameter and a 10 bolt hub looks tiny compared to a 60.
    Ira
  4. XHitman396
    May 3, 2002
    620
    hmm.. that all makes sense.. so what's the smallest backspacing i can get away with while still keeping the wheel and drum brakes from touching on 15x8 wheels, as to keep it as close to 'stock looking' as possible?? 31" tires, maybe 35's in a couple years.. thanks
  5. sandawgk5
    Oct 28, 2003
    6,881
    I run a 15X8 with 4.25" backspacing and they do not touch the drum brakes at all:D .
    Here are some pics to show how much stick out I have. These are 37X12.5 MTRs
    Ira
