Wheel Stud Help?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by joryyroj, Jul 28, 2003.
  1. joryyroj
    joryyroj Registered Member
    Mar 13, 2003
    32
    Wylie Texas
    I have a 1970 K5 Blazer that has a 4 inch lift and 35x12.5 15" tires and 15x10 each wheels with the original 4 wheel drum brakes and wheel studs. My problem is my new aluminum wheels are thicker then the original steel wheels, and therefore my acorn style lugnuts are only grabbing about a quarter of an inch of the stud. I have had to pull over and tighten the wheel studs repeatedly and I am worried that the wheels may fall off without longer studs. I have tried oRiellys, Autozone, and Napa trying to find longer wheel studs. So far no luck. Has anyone else had this problem, and if so how did you fix it? Were you able to use wheel studs from another make/model/year that were longer? Any help would be great or you can email me at jory.pai@verizon.net
    Thanks in advance.
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Go to any Napa, Shuck's, Autozone, whoever, ask for the line of, DORMAN Product's. They have a catalog full of wheelstud's, in many many size's.
    If the above place's won't drag out a Dorman book, call around to see who has Dorman.
  3. joryyroj
    Mar 13, 2003
    32
    Wylie Texas
  4. jasonkh2tg
    jasonkh2tg 1/2 ton status
    Mar 27, 2003
    139
    MPLS MN
    Well who sold the rims to ya, if they said it will fit a 70 or that's what /forums/images/graemlins/k5.gif the book said you need to do some serious As* kicken.... /forums/images/graemlins/k5.gif
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I think they also sell lug nuts with a longer shank on them for thicker wheels.
  6. joryyroj
    Mar 13, 2003
    32
    Wylie Texas
    Thanks for all of the great ideas. I was able to find longer wheel studs in the dorman catalog as Don H had recommended. Thanks Don. I had to go with wheel studs that were .300 of an inch wider on the knurl for the fronts but we were able to hammer them in the hole.
    Thanks again everybody. Now my wheel hopefully will stay on!
  7. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    i got longer studs from napa.they were like 3 bucks appiece but you will have what you need.
  8. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Glad to hear You found the correct length stud's. /forums/images/graemlins/grin.gif
