wheel stud troubles...maybe
Discussion in 'The Garage' started by burbanbeast, Feb 19, 2007.
  1. burbanbeast
    burbanbeast 1/2 ton status
    Jan 24, 2006
    103
    Collierville
    in the past year ive lost two tires(see picture for defintion of lost) and almost lost two more. and ive really run out of clues as to what is causing this. i replace wheel studs and lug nuts everytime it happens but it continues to plague me and plagued the past owners as well. would upgrading to some higher grade studs help me? or am i just doomed to this forever. just in case the weight of the vehicle has anything to do with it i drive an 89 suburban on 35s. but yeh just lemme know what u think please(and if you cant see the picture my tire fell off)
  2. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    DO you continually re-torque your lug nuts after you install your new studs?
  3. burbanbeast
    Jan 24, 2006
    103
    Collierville
    on the front i press em in and then torque em when i put the wheel back on but its only one time unless i take the tire off again. and on the back i ran it in with a lugnut and lots of washers over and over.
  4. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    I had this same problem with my 1/2 ton burb when I put on my lift and new wheels/tires. I don't know if it was weight or aluminum rims that caused the problem to start.... but I solved it by going to 1/2" studs instead of the little 7/16" studs
  5. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    i felt that coming on one day and luckily i caught it in time and it was loose lugnuts and the studs were breaking i had 3 left! its amazing it was still driving. oh i had aluminum rims and 35 on a k5. ive heard but not confirmed aluminum is the culprit
  6. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    What kind of wheels, studs and lugnuts are you running?
  7. burbanbeast
    Jan 24, 2006
    103
    Collierville
    well they are aluminum wheels. a 7/12-20 wheel stud and 7/16-20 lugnut for the back im pretty sure the front is the same but not 100%
  8. cbbr
    Jul 17, 2004
    14,681
    You sure that you have the right type of lugnut? Some rims require their own lug nuts.
  9. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
    are the studs shearing or stripping?
  10. resurrected_jimmy
    May 23, 2005
    2,241
    the quality of the studs and angle of the shoulder on the lug nuts will have an effect on how they hold
  11. burbanbeast
    Jan 24, 2006
    103
    Collierville
    yeh i do believe i have the right lugnuts they kinda taper down at the bottom and fit snug into the hole in the wheel. and the first time the studs definetly stripped. when i got down and looked at em there was metal all in the threads of the studs(front driver in the picture). and the second time they broke in half(rear pass) but it looks like the lugnuts are just slidin off the studs when everything does fall apart
  12. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    I used to run some cheap aluminum wheels on my blazer and my rear wheels would come loose all the time. I changed to steel wheels and haven't had a problem since.
  13. burbanbeast
    Jan 24, 2006
    103
    Collierville
    mayb i need to makew the swap
  14. cbbr
    Jul 17, 2004
    14,681
    I run H2's (alum) and have never had a problem at all.
  15. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Some aluminum rims require a shouldered lug nut that will actually fit inside the hole for the rim. This keeps the rim from riding on the stud and also centers the rim on the studs. They are available with conical seats or not depending on your rim application, it would be something to look into.
    Check here to see what I mean
    Ira
  16. burbanbeast
    Jan 24, 2006
    103
    Collierville
    the lugnuts i have are close to that. see on those where it starts to shape into a cone towards the bottom? thats how mine are just withouth the "shank" like on those
  17. sandawgk5
    Oct 28, 2003
    6,881
    Right what I am saying is with aluminum wheels you may need the shank style lug nuts. I know when I was younger all aluminum rims required shanked lug nuts.
    Ira
  18. burbanbeast
    Jan 24, 2006
    103
    Collierville
  19. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    Hub centric wheels use a shouldered lug.
    Lug centric use a conical lug.
  20. burbanbeast
    Jan 24, 2006
    103
    Collierville
    yeh you pretty much lost me with that one. the only thing i can think of that might relate to what your saying is the way the wheel sits against the hub. if its that case then my wheel sits all the way back on the hub where you can see the whole stud with the lugnut off.
