wheel studs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Jan 29, 2001.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I have the little 7/16 studs on my 10 bolts, but since I'm planning on going to a 14 bolt SF, I want to upgrade to 1/2 or 9/16. what is involved in this for the front axle? I know its pretty easy in the back, just hammer them out and put the new ones in, but there isn't much access for the front studs, but I will be doing work up there soon, changing balljoints and u-joints. Where can I pick up a set of these? Will they even fit in the front without modifications?
    90K5
  2. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    use a brass punch and beat them out to seperate the hub and the rotor....just like changing rotors except you put the new studs in............i did this two years ago to swap rotors..its all i remember doing...pretty easy
    AIRBORNE!!
  3. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    I did a 14mm change in the rear and have the studs to do the front. I wrote a tech. artical on the rear and will do the same for the front. If you can wait about a week or two, I should have it done. I plan on e-mailing it to Steve so he can put it up, if he wants to!
    <A target="_blank" HREF=http://www.blazen91.coloradok5.com>http://www.blazen91.coloradok5.com</A>
    Protect the land FOR the people
    Not FROM the people
  4. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Hey Blazen, what is the part # for the 14mm studs that fit into the old holes occupied by the stock 7/16" studs??
    ken
