Wheel width opinions sought - Poll
Discussion in 'The Garage' started by BudTX, Nov 27, 2005.
What size wheels to run?
  1. 16.5x9.95
    16 vote(s)
    61.5%
  2. 16.5x12
    10 vote(s)
    38.5%
  1. BudTX
    BudTX Registered Member
    Oct 4, 2005
    36
    Kansas
    I have a 1983 K20 with a 700R4, 350, 10 bolt front, 14 bolt SF rear, open diffs. The truck will see 50% gravel road driving and 50% mud.
    I have a set of 35X15.50-16.5LT TSL/SX tires on the way that I got a smoking deal on. I am going to run a 6" spring lift (another good deal from a mechanic friend), and am trying to decide on wheels to finish out this phase of the build up.
    I am probably going to go with steel wheels, something along the lines of Rockcrawlers. The extra weight versus aluminum is a bit of a concern, but I'd rather have the ability to hammer out dents if necessary.
    My question is, do I want the 16.5x9.75" wheels, or go with the 16.5x12"? I kind of like the idea of the narrower rim, to help hold the bead on the 16.5" tire. On the other hand, the wider rim will widen out the tire, and may help with flotation.
    Thoughts/comments?
  2. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    i like the look of the wider rims but a narrow rim is the cheap mans beadlock...
  3. 74757685k5
    74757685k5 1/2 ton status
    Nov 13, 2004
    258
    montana
    wider you will have to trim more sheet metal.
  4. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    if 8" had been an option, I would have voted for that. I'm gonna run my 33x12.50x16.5 TSL's on stock 16.5x6.75" wheels. The ultimate wheels would be recentered hummer beadlocks. I would NOT go with a 12" wide wheel, with 16.5 wheels, because you need all the help you can get holding a tire on without a safety bead ;)
    James
  5. Inu-Hanyou1776
    Inu-Hanyou1776 1/2 ton status
    Oct 1, 2005
    1,345
    Murphy, NC
    Go with the narrower wheels if you're not planning on running beadlocks or a wheel equipped with safety beads, they'll hold the tire on better.
  6. BudTX
    Oct 4, 2005
    36
    Kansas
    That's pretty much where I am headed. Keeping the wheel narrower for the rare instances where I may need to air down will probably be cheap insurance.
    The poll results are a lot closer to 50/50 than I was expecting.
  7. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    yeah, a 12" rim is way to wide for a 35. For a 42 or 44 maybe... but nuttin smaller than that needs a 12" wide rim.
    j
  8. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    werd
