Wheel wobble on a Dana 60
Discussion in 'The Garage' started by MuddNutz, Aug 30, 2004.
  1. MuddNutz
    MuddNutz Registered Member
    Nov 3, 2002
    61
    If you jack up the wheels on Dana 60 and you can wobble it back and forth is that a bad wheel bearing? Are the breaks on a Dana 60 a lot better than a 3/4 ton dana 44.
  2. MuddNutz
    Nov 3, 2002
    61
    Does anybody know?
  3. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    could be worn wheel bearings, worn king pins, is the knuckle stationary when you move the wheel back and forth
  4. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    broken nylon bushing under the spring under the king pin cap.
  5. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    The spring king pin spring is either toast or the nylon bushing is shot (as mentioned above) either way the upper king pin kit comes with both parts ($20 each side for the uppers). Uppers are a 30 minute unstall if the original pins are usable.
  6. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Yeah, check that stuff, we've got the kingpin spring and bushing kit alone, wheel bearing kits, full kingpin rebuilds, etc. It's not too expensive to fix any of it, you'll probably get away pretty easy.
    YES, 1 ton brakes are way bigger than 3/4T.
