wheelbase: front > rear?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by spincast375, Sep 21, 2005.
  1. spincast375
    spincast375 1/2 ton status
    Aug 20, 2004
    194
    Tennessee, U.S.A.
    Is it possible that the front wheelbase is greater than the rear? We have a Dana 44 up front and a Corp 12 in the rear. I was following the Blazer yesterday in the car and it certainly appears the front tires stick out about 2" more on each side. If this is not an optical allusion, would this have an adverse affect on the steering? tire wear? handling? safety?
    Anybody know a good front end shop in TN?
  2. ARAMP1
    ARAMP1 Aviator Extraordinaire
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    Wheelbase is the distance between the front axle and the rear axle of a motor vehicle. It determines how sharply the vehicle can turn in a given direction.
    I believe you are thinking of track, the distance between parallel wheels.
    And, I'm not 100% on this, but I believe the rear track is approx. 3 inches shorter than the front.
    ARAMP1
  3. spincast375
    Aug 20, 2004
    194
    Tennessee, U.S.A.
    You're right. What was I thinking? Too little coffee, too early in the morning.
  4. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    this is normal. i believe the measure of wms(wheel mounting surface) to wms on the rear of a halfton is 65" while the front is 67" stock.
    of course its possible you have spacers up front as well.
  5. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    The rear is slightly narrower than the front. I believe the reason is related to a slightly tighter turning radius.
