Wheelin w/ Sm465
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TXsizeK5, Aug 29, 2001.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Is it possible to get mud in your clutch??
    How much abuse can a rebuilt stock clutch take?
    ie: while pulling somone out, and wheeling hard??
    87 k5, 6in, 35" BFG muds.
    Future Mods: KNfilter, Flowmaster Force2 Catback, change the 5.5 blocks and .5 addaleafs to 6in springs.
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    You can get mud in your clutch, but it will be wiped off like a disc brake. Centrifugal force tends to keep it away from the springs and splines. Stock clutches will take quite a bit, obviously a Centrforce or other HD aftermarket is better, but stockers will survive pretty well.
    If the shoe fits, get another one just like it
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. Grim-Reaper
    7,385
    Atlanta
    Well that's not totaly true. I have seen a mud filled clutch bring a farily well built truck to it's knees and have to be trailered home. Ended up being able to be cured by dropping the inspection cover and having somebody hold the clutch while somebody else hosed it out. It was a ford.
    Really for a Mud truck a Auto is almost better so the driver can keep both hands on the wheel. Wheel spin is key and Shifting mid way through a pit is a hell of a lot to do when your full throttle.
    Where a stick is nice is for crawling if you got the gear in the pigs to handle dumping the clutch at idle and not stalling the engine at high idle.
    It's not my damn planet monkey boy!
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>communities.msn.com/OffroadK5s</a>
    75 Jimmy, Dollar
    79 Chevy Blazer, Her's
    70 Chevy Burb
    Grim-Reaper
  4. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Wow! I've never seen one do that! - Ditto on the auto. Much nicer to keep the wheels spinning in mud/sand.
  5. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
  6. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    Have to agree with Grim here. When I used to wheel in the mud I have come out of the trail hit the gas and the tach went to the moon. I could only drive in 1st if I tried to go to second it would just slip. Went to a pressure washer and you would be amazed at the amount of muck that came out. It took three days before my clutch stopped feeling like a wet sponge when you pushed it in.
    I thought I was wrong once,
    but I was mistaken
  7. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    If you did get mud in it, how wold you clean it out?
  8. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    There's a tin inspection cover that you could remove to spray the mud out. I have wheeled some deep sloppy mud and haven't had a problem with the clutch, but my cover is still pretty straight and prolly keeps the worst of the mud out. A bad clutch fork boot would be prolly where the mud can get in and clog the works up.
    Rene
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    An auto is probably better for a mud truck. My friends have had problems with them holding up though. My one friend's TH 400s couldn't even take the abuse that he puts to them with big block and his driving habits.
    I'm going with an SM 465 because I don't like driving a truck with an automatic. My 700R4 has always worked well, but I wanted a stick shift before I even got my truck, so I'm swapping in an SM 465. Also, I want to stop worrying about overheating my 700R4 while towing, nor do I want to continue to worry about my chain in my NP 208.
    Tim
  10. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    <blockquote><font class="small">In reply to:</font><hr>
    A stock TH 400 would hold up to a 10 second car.
    <hr></blockquote>
    And it won't hold up to a zero-traction mud truck?
  11. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    What does it feel like when the clutch slips??
  12. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Got a SM 465 and found out last night what its like shift through a mud bog...the story kinda goes like this
    I Got Stuck!!! Worst part is a buddies Heep Hairykee with 32s pulled me out(he loved pulling the "chevy" out--Thats braggin rights for a heep")...then again I made the mistake of one going through with 33" swampers and making big ruts and two of going back through in L gear when I went to shift to first gear lost momentum and when I let out in first my front axle high centered in the ruts and the back just stayed put spinning....as far as clutch problems...none yet...changed a throwout bearing which was a pain to get to...when you push in the clutch it will sqeal somethign awful if its the throwout bearing
    1985 GMC C-10 Shortbed
    1984 Chevy K-5 Blazer
    1982 Chevy C-10 Longbed
  13. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    you dont shift in the mud with a 465. pick a gear and try and push your foot through the rad
  14. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    If your friends th400 cant hold up then he needs to find a different rebuild shop. The th400 in my firebird has lasted 3 yrs of drag racing and street use. It was a stock rebuild. 525 hp and 650 ft/lbs.
    86 Jimmy 4"lift 35"MTRs Other cars 69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    His dad rebuilt it, who is very good. He didn't even put a gallon of gas through it before it went out again. Obviously something wasn't done correctly.
    The driver is a nutcase and gets far from zero traction. He has 18" wide Boggers. He didn't actually burn up the tranny, we just put the 4 speed in it because the competition was a few days away and he needed his truck working QUICK!
    Tim
  16. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    I was going to say, its pretty hard to break a th400. They will normally let you know well in advance when their time has come to get rebuilt.
  17. AGM73k5
    AGM73k5 1/2 ton status
    1,246
    Portland OREGON
    If I remember right white__knight, the one with the s-10 conversion that runs mudbog races uses a 465/205 combo. Someone correct me if I'm wrong :)
    -Aaron
    ___ __ _ _ ____ __
    AGM73k5 -- ajgm1@yahoo.com
  18. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Your correct he uses 465/205 setup.
  19. michaelm
    Feb 2, 2001
    872
    SHE i believe teresa drives no?
    autos (or lencos) rule the bogs
  20. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Wish my mud truck had a Lenco! And they can get 8:1 first gear in the 5 speeds!!!
    Lift It, Lock It, LIVE IT!!!
