Wheels - 16.5 / 6 lug?
Discussion in 'The Garage' started by Mreetz, Apr 5, 2002.
  1. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    Is there such a thing? Are there adapters you can buy?
    Thanks!!
  2. creampuff90k5
    creampuff90k5 1/2 ton status
    Feb 15, 2002
    142
    New Jersey
    We are talking about 6x5.50 right? Yep, there are several companies that make 16.5 wheels for this bolt pattern. I don't know them all, but you might want to start with Weld and Elite who have 'em for sure. Hope this helps...
  3. Mreetz
    Jun 26, 2001
    1,282
    Is that the pattern for a chevy 6 lug, then you bet.
    I'd like to get a set of them. Are they hard to find?
  4. creampuff90k5
    Feb 15, 2002
    142
    New Jersey
    Yeah, 6x5.50 is the bolt pattern you need. I wouldn't say these wheels are hard to find, but the selection is not going to be as vast as it would be for say a 15" wheel. Check out the websites of the major manufacturers, starting with Weld, who I know makes them.
  5. carguy64744
    carguy64744 Newbie
    Jul 1, 2006
    4
    el dorado springs mo
    i am looking for a set of these and have only found one company so far who make them search for rock crawler wheels they are series 51 that is the only ones i have found so far if anyone else finds any others i would like to know
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Check eBay and type in "weld racing". There should be a few on there.
  7. diesel4me
    Jul 24, 2003
    17,553
    939
    Massachussetts
    had some!..
    I recently sold a set of 16.5" - 6 lug factory rims I used on my 72 K5--they were off a K1500 GMC pickup,1970 vintage..I had to use some aluminum spacers so the rims wouldn't rub on the calipers,since they were intended for drum brake trucks originally..
    I've seen many car trailers with 6 lug 16.5" rims--maybe a trailer supply place will have rugged steel versions for reasonable money..they will probably be "skinny" though,as trailers usually use narrow rims about 5-6" wide..also make sure the center hole will be large enough to fit over your hubs..:crazy:
  8. carguy64744
    carguy64744 Newbie
    Jul 1, 2006
    4
    trailer wheels are to narrow i found alot of stock 8 lug but no 6 lug just need a 16.5x10 6 lug
  9. barneybasher1010
    barneybasher1010 1/2 ton status
    Sep 25, 2005
    908
    PORTERVILLE CA
  10. mr.smartass
    mr.smartass 1 ton status Premium Member
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
  11. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    quick question, why do you want 16.5s? I got mine cause the tires I got for them were cheap, and the wheels I got from a member here for cheap and needed them to go 8 lug. when the air pressure gets low enough the tire will fall off the bead and I dont like that but it was the cheap solution at the time and I will either buy 15s or beadlocks when the money comes around. not trying to presuade you against them I just dont believe they are very good offroading rims.
  12. carguy64744
    carguy64744 Newbie
    Jul 1, 2006
    4
    i had 16.5 tires on my last truck and still have a couple good sets from it i like the tires and would like to keep using them i have never had problems with them yet and i get the tires cheap i eventually want to get some beadlocks but one thing at a time
  13. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,081
    486
    Grand Rapids area
    I had some Krager 6-lug 16.5x9.75 wheels, but I sold them because I prefered the tire selection and bead retainment of 15's. I know that there were a few sources for steel replacements back then. They are definately more common in 8-lug, but many wheel manufacturers still offer them in 6-lug.
    The thing that makes me think about 16.5's again is that Hy-tec retreading offers 37" hummer retreads for cheap.
    Before you buy some 6-lug wheels, make sure a set of 8-lug axles isn't in your future.
  14. carguy64744
    carguy64744 Newbie
    Jul 1, 2006
    4
    8 lug axle would be nice swaping in a solid axle aint cheap so that will be in the future i need tires know i have a set of 16.5 can usually find then descent priced can get wheels cheaper than buying new tires i think i will just get a set of steel wheels for know
  15. big dan
    Aug 1, 2005
    2,656
    29
    Arkansas
    you could get some hummer beadlocks and recenter them with 6 lug centers. then you'd have what you want and wouldnt have to worry about losing a bead. I plan on getting some cause they are pretty cheap but Im already 8 lug so Ill have to use 8 lug centers.
