Wheels and tires?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ZfromNJ, Sep 25, 2002.
  1. ZfromNJ
    ZfromNJ Registered Member
    Jan 26, 2001
    99
    New Jersey
    Is i better to run a 4 inch lift with 35's or should I go with a 4 inch lift and run 33's but with a larger rim? I was thinking of running 33's with a 15 x 10 or a 15 x 12 rim! What do you guys think?
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Depends. Is it for look's,or function? I like the look of a smaller lift with big tires,and fender trimming. I'm gonna run 35's on a 8" wide rim with a 4" lift. I also have trimmed my fender's and have a 1" body lift. Everyone has there own opinion,do what you want too. /forums/images/icons/grin.gif
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    just smack the 35's on with out a lift and let it flex a bit. cut off all offending sheet metal that is then bent.
    well, that is how greg did it /forums/images/icons/smirk.gif
  4. 305twistedchevy
    305twistedchevy Registered Member
    Aug 29, 2002
    6
    Ocean County NJ
    hey zfrom nj not to get off topic but i noticed you are from NJ i was just wondering what part i'm from oceancounty NJ lacey to be exact thanks
  5. ZfromNJ
    Jan 26, 2001
    99
    New Jersey
    Hey twisted I am from Union up in northern Jersey but I do have relatives in Forked River. I know the new baseball coach down at Lacey High School.
  6. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Go with the 35's...if you have the gearing for them...at least 4.10's.
    I am a jersey boy too.
  7. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">Yeah thats true. What gears do you have?
    also from NJ
  8. ZfromNJ
    Jan 26, 2001
    99
    New Jersey
    I am not sure what gears I am running. I would have to assume that they are stock so whatever stock is? I am realitively new to all of the mechanical stuff. I am suppose to get my truck back from the shop today because my tranny blew. Of course it was a 700r4!!!
  9. Grim-Reaper
    7,385
    Atlanta
    You may have 3.08 gears and I would not go to a larger tire till you cange the gears. It roasts the tranny when the gearing is wrong. Put a AUX tranny cooler on there also. On a 700R4 with 33's I would run a 4.10 gear. 35's I would run a 4.56. If you run a 3.08 gear then get use to rebuilding the tranny.
    In your glovebox should be the build sheet. One of those codes indicates the gear ratio. I would make a post for Build sheet codes. Several people have them.
