Wheels squeek
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JimmyJuneau, Aug 23, 2001.
  1. JimmyJuneau
    JimmyJuneau 1/2 ton status
    Apr 11, 2001
    811
    Juneau, Alaska
    Ok my front wheels squeek. I am able to step on the brake a little bit and still keep the truck moving and the squeek goeas away the brakes are in good conditon along with the rotors do you know whats wrong?
    1985 GMC JIMMY
  2. muddysub
    Jun 23, 2001
    10,454
    493
    my garage, Henderson, NV
    sorry man i don't.
    scott,
    1989 suburban 3/4t 4" lift soon to be rollin on 33s, tbi350
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    If stepping on the brake causes it to stop squeaking, you've got a brake issue. Get a bottle of Permatex "disc brake quiet", and lay a coat on the backs of the outboard pads, and a single bead along the inboard pad backs.
    Dos mas Tecates!!!
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  4. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Couldn't hurt to hit all your lugnuts with a torque wrench and eliminate the possibility of a loose wheel... If you don't know the exact figure for your particular wheels, 80 ft/lbs for steel and 100 ft/lbs for aluminum seems to be a good rule of thumb.
    It's a happy day in Marine Aircraft Group 49... 405 is ALIVE!!
    [​IMG] <font color=green>Semper Maintenance!<font color=black>
  5. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I go with Pugsley on this one. Sounds like a vibration coming from the pads. Get some "disc brake quiet" Kinda like spray paint or you can smear it on too.
    That jeep thing? Yah I understand it....... Like my Blazer? <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  6. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    3rd
    sounds like pad squeak
    It needs a bigger motor.
    what's in it now?
    doen't matter it NEEDS A BIGGER MOTOR
    89 350tbi/700r4h/np208/4.11's
  7. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    I'd check the top ears of the outer brake pads...if those ears aren't clamped down real good, then they'll make some noise.
    '73 K5
    Chevy good...Ford bad
  8. blackdog
    blackdog Registered Member
    Aug 8, 2001
    98
    New Jersey
    <font color=black>It's a real long shot, but I had something like this once, and after a week figured out it was just something jammed into the tire tread. Popped it out with a screwdriver, and Voila! Of course, this probably has nothing to do with your problem....
    <font color=black> "Where did all these people come from, and how soon can they leave..."
    -OLD 97's</font color=black>
    <a target="_blank" href=http://www.k5.batcave.net>www.k5.batcave.net</a>
