Wheels- Tyres
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JORGE, Jan 30, 2003.
  1. JORGE
    JORGE 1/2 ton status
    Jan 10, 2001
    213
    VITORIA-GAZTEIZ(ALAVA)BASQUE COUNTRY,SPAIN
    Somebody knows where could i find a Wheels-Tyres and his advisable sizes table?
    Or if somebody knows what is the minimun wheel width for 33x12.50...
    Thanks a lot.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    minimun wheel width is probably 7". 8-10" is the most common for 12.5" wide tires.
  3. JORGE
    Jan 10, 2001
    213
    Hi Hossbaby,
    I,ve seen in tyres1.com th tables.Bfg says 8.52 min. MT 8".
    Maybe this depends the brand .
    Thanks.
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> What the tire manufacturer says and what actually works is a bit different. 8" would work fine, 7" would even work OK but you'll get a bit more wear on the center of the tire. I'll be running a 15" wide tire on an 8.25" rim, and many others on this site do the same thing. </font color>
  5. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I am currently running a 15.5" wide tire on a 9.75" rim. I used to have some 12.5's on some 6.5" rims. Worked, but not the best. I also had some 9" wide Centerlines for 12.5 tires, they worked great.
  6. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    how bad will 39/15x18 tire on a 10" rim be?
  7. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    10 is a bit narrow, you would be better off w/ a 12...but if 10's are what you have they will work. Your sidewalls will bulge out a little more and have more of a chance of getting cut/poked/damaged.
  8. JORGE
    Jan 10, 2001
    213
    8.5,8.25 etc are sizes almost impossible to find around here.They pass from 8" to 10".I,ve Yokohama tires.Yokohama says the best width for 33x12.50 is 10",aproved 8.5 to 10.
    I,ve them in 6 " and works very bad. 10" has the eternal rubbing trouble,and i,m afraid for the bearings and other pieces,wich would go more forced with this rim width.But they looks so great...
  9. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    Actually a narrow rim with a wide tire will make the sidewall less exposed to get cut or damaged.
  10. 98sub454
    98sub454 Registered Member
    Jul 18, 2002
    74
    La Habra, CA
    i just got a set 0f 17/40-15 ground hawgs, denman reccomends a 10" rim so thats what i got, it looks fine to me. nobody knows the tire better than the people that built it. just remember that if you run a different size rim than what they say to use then the specs that they provide will be a little bit off as well
  11. JORGE
    Jan 10, 2001
    213
    I,ve been watching an American Racing set in an online shop.But i can,t find this wheels in the A.Racing catalog.They don,t appears in any place.They are the Pionner model(ARE 48) with a -38 mm offset.
    Somebody has watched this wheels any time?Somebody knows the backspacing?
    Thanks a lot.
