Wheels
Discussion in 'The Garage' started by darenofears, Nov 21, 2006.
  1. darenofears
    darenofears Registered Member
    Jan 25, 2005
    47
    Indiana
    what happens if you put a tire that is approved for 6.5 to 8 inch wide tires on the 8 inch wide rim.
    does it affect performance
  2. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    it will affect the look of the tire more than anything, a bead will hold better on the 6.5 wid rim when aired down...
  3. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    293
    Truckee, CA
    Tire may end up shorter than actual spec size. It will be wide and short. Large, probably flat tread surface. May tend to wear on outsides of tire. Narrower rim will force tire to bulge more in teh center of the tread, and may be a little taller/narrower than planned.
  4. darenofears
    Jan 25, 2005
    47
    Indiana
    thanks guys, also can you run a 16x7 rim on an 02 blazer?
