Wheels??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by loudandproud, Jul 14, 2000.
  1. loudandproud
    loudandproud 1/2 ton status
    Jun 27, 2000
    451
    Ham Lake, Minnesota
    How do you get the wheels to stick out past the fenders?? Does that have something to do with the rims?? And is it called positive offset??
  2. chevy4x4
    chevy4x4 1/2 ton status
    Apr 27, 2000
    1,454
  3. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    <font color=green>The rear wheels are set more narrow than the fronts... don't ask me why. Wheel spacers are available to even out the back to match the front. Check out the product reviews on this site.</font color=green>
    BLAZE IT UP!!!
  4. MICHIGAN BLAZER
    MICHIGAN BLAZER 1/2 ton status
    296
    Middleville Michigan
    it's called backspacing. I don't know much about it. I think i've heard it called positive off set though too. I don't half understand backspacing so I'm not the person to explain what you need for your tires to stick out further. I do know it's the rim & where your tire sits in relation to the fender depends on how much backspacing your rims have. I was trying to figure that crap out for my husbands cherokee(they're finicky about backspacing & rire rubbage)....I just gave up.
    <font color=red>MICHIGAN BLAZER
    <font color=green>89 Fullsize Blazer
    87 Cherokee
    65 IH Scout
  5. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    if you changethe backspacing (positive/negative offset)too much you are going to run into major problems with steering, rubbage, and bearing/ujoint wear. better to get wider rims and tires and leave the correct backspacing. Your truck will thank you.
    but the spacers in the rear are a good idea.
    shaggyk5
    aint nuthin in the world like a heavy chevy!!
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Positive offset is completely different. It is where the wheel curves in from the center. I think they are only for front wheel drive cars and they would look pretty dumb on trucks.
    90K5
  7. realsquash
    realsquash 1/2 ton status
    Jul 12, 2000
    778
    SE WI
  8. Big B
    Big B 1/2 ton status
    222
    fort worth texas
    i was told that the rear tire are set a little more to the endside of the axle so your rear tires do not go threw the same ruts as the front i do not know if this is true just what i was told.
    bigb4x4.coloradok5.com
