When a 203 goes bad.?.?.?.?. and I'm pretty sure it gets worse
Discussion in 'The Garage' started by justhorsinaround, Aug 30, 2004.
  1. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    When a 203 goes bad.?.?.?.?. and I\'m pretty sure it gets worse
    .....does it go bang when goin from reverse to drive or when takin off from a light or maybe when runnin through the gears. Or is it maybe the Turbo 350 or maybe somethin else. I don't think it's the motor mounts cuz on account the motor doesn't shift when goin from drive to reverse and vice versa. Any thoughts or concepts would be greatly appreciated.
  2. justhorsinaround
    Sep 16, 2003
    6,798
    Re: When a 203 goes bad.?.?.?.?.
    Anyone?
  3. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
    I'd check the ujoints first
    good luck
    Bob
  4. justhorsinaround
    Sep 16, 2003
    6,798
    Sorry I forgot to mention the u-joints are fine as I checked and driveshaft is next to brand new. By the way, I forgot to mention that I feel the bang underneath my feet. It almost feels like bad mounts you know like when they bind up and then release with that bang. But like I said earlier the mounts appear to be fine. All the crashing and banging seems to be amidships.
  5. fatbob
    Jul 3, 2003
    420
    Phoenix, Az
    Check the trans mount where the crossmember bolts to the tranny/tcase adapter. If that's loose, that heavy tcase could break the rear of the aluminum transmission. That happen to me twice, but I also did not have the brace from the tcase to the engine. IIRC you don't have that brace either, do ya?
    Bob
  6. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Might check the bellhousing bolts, adapter bolts, adapter mounting bolts, flexplate /forums/images/graemlins/dunno.gif
  7. justhorsinaround
    Sep 16, 2003
    6,798
    I thought about the flexplate as well. No Bob, I don't believe we have that brace either.
  8. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    mine did all kinds of wierd crap like that when it finally went out, so I took it out and tore it apart and all the gears were toasted... /forums/images/graemlins/pimp1.gif
  9. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    could be a stretched chain in the T case.
  10. diesel4me
    Jul 24, 2003
    17,584
    945
    Massachussetts
    I had a 203 in my 74 K20 that used to "skip" when you punched it at a red light,or under heavy load(like pushing snow)and it was the chain all stretched out--guess it didnt like the tourque of the 454 I had in it at the time.I got another 203,and it did nearly the same thing,so I finally bought a 205 case from a 72 vintage and swapped it in--no problems with that case except the shifter bolt broke off in the adapter after a few years.I think the second 203 was in ok shape,I'm fairly sure it was the shifter being out of adjustment that made it act up--it worked fine in the truck I pulled it from,someone said it might be the differential gears in the tailshaft that were bad,but I never looked--its still out in my shed where I put it 10+years ago... /forums/images/graemlins/crazy.gif
  11. justhorsinaround
    Sep 16, 2003
    6,798
    So is it bad when you hear what really sounds like chain on metal when goin really slow and now a nasty vibration up till about 35? /forums/images/graemlins/whistling.gif
    Just checkin to make sure. /forums/images/graemlins/screwy.gif
  12. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,175
    132
    Phoenix AZ
    I'd venture to say that what you are hearing is bad.
    I have one here if you need one (unknown condition, but might be better than what you have).
  13. justhorsinaround
    Sep 16, 2003
    6,798
    Marv said he had one as well so maybe between the two of them one could make a single good one? What do ya think?
  14. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    Have someone look under it when you put it in gear and watch the tailshaft mine goes almost a half turn I had the same symptoms
    just need to install my 205!!!
  15. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Tighten the pinion nut maybe , we both have 12 bolts , and mine was loose and made that noise/vibe , didn't find it until AFTER I got the Cv shaft (needed CV anyway) /forums/images/graemlins/k5.gif
    BTW Allan , just to make you chuckle , those 4 degree shims I gave you and would never need , are just what I need for the new truck /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  16. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    I blew the chain to bits but could still drive it, do you have a part time kit? Pop off the access hole and have a look inside, it might have something to say!
    also I have a 27 spline 205 with adapter and shifters for sale......
    pm me if you are interested
  17. fatbob
    Jul 3, 2003
    420
    Phoenix, Az
    Re: When a 203 goes bad.?.?.?.?. and I\'m pretty sure it gets worse
    Well what did ya find out with it? /forums/images/graemlins/ears.gif
