when are we going to have an alternative to the dana 60?
Discussion in 'The Garage' started by COCHEV, Sep 6, 2002.
  1. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    is this forever going to be the only upgrade from a 44? i can only see them getting more expensive - if that's possible. if only there was something esle to install that would be a strength upgrade and not so damn hard to find and expensive. i've read up a bit on the ctms and chrome moly shaft rout but the money involved in that would add up to a 60 and still not be as strong. too bad gm didn't mass produce one tons like they did 1/2 and 3/4 tons. /forums/images/icons/frown.gif
  2. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    Unimog axles are gaining popularity and probably cost about as much as a 60 from a specialty place.
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    rockwells are also becoming more common place. and are easier to go to coil overs.
  4. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    yeah and i found a few sets of them about 60 miles from my house...
    cant get in touch with the guy yet...
    YET...
    grant
  5. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    cept rockwells are so dang heavy ya need TWO winches to leave the mudd hole /forums/images/icons/crazy.gif that sux. maybe ill start making 14FF fronts, who wants one? ill take orders now, and when i get a start order of $ 50,000.00 ill fire the shop up /forums/images/icons/grin.gif /forums/images/icons/wink.gif
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    60s are still a bargain as you pointed out
    best $1000 peace of mind you can put under your truck
  7. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    im wondering if we will eventually start seeing a lot more newer ford and dodge dana 60s swapped in along with a t case change cause they are the only ones still putting 60s up front. once these trucks start getting older and showing up more in the junk yards. i think i read in one of the mags that the mid 90s dodge trucks will become the next affordable platform to use for an off road rig.
  8. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    I too, believe that the Furd D60 is the best kept secret. Cheap (about half of what a gm 60 cost), and noone is really snatching them up. plua they are RR.
    rob
  9. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Dana Corporation should start making D60's for the aftermarket...............figure a $2000 front end would be worth it to us and they could sell a ton of them. /forums/images/icons/laugh.gif
  10. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    1-will it bolt right up to a chevy?
    2-what has to be done to do so?
    3-and whats RR?
  11. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    I think it bolts up but the pumkin is on the drivers side. RR is reverse rotation. The Ford D60 is a high pinion dedicated front diff. The Chev version runs rear gears backwards...
    Rene
  12. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    RR is reverse rotation. Otherwise known as high pinon. They are driver's side drop, so you will need to switch to a F*rd transfer case. The 78-79's have the same spring spacing as GM's.
  13. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    oh god, then we now have the jeep syndrome,
    "built jeep tough with chevy stuff" ....................ill stick to looking for a chevy d60 just outta EXPENSIVE SPITE
    /forums/images/icons/grin.gif /forums/images/icons/grin.gif /forums/images/icons/grin.gif /forums/images/icons/grin.gif /forums/images/icons/grin.gif /forums/images/icons/grin.gif /forums/images/icons/grin.gif /forums/images/icons/grin.gif /forums/images/icons/grin.gif
  14. rodzzilla
    953
    Grinnell, IA
    Just remember that it is still a Dana and a NP product /forums/images/icons/grin.gif . Plus, I am converting my 60 to Chevy outer knuckles so I can easily convert to 35 spline outters. /forums/images/icons/wink.gif
  15. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    Could use a case from an IFS chev???
  16. Jeff427
    Jeff427 1/2 ton status
    May 22, 2000
    1,186
    Gladwin, MI
    This is not directed at anyone in perticular.
    Ford front axles are NOT reverse rotation, they are reverse CUT to get the pinion on top. They still rotate the same way as everything else.
  17. yeild2me
    Jan 7, 2001
    1,309
    fayetteville, nc
    ok, you got me.
    Keith Deal and I talked about this one day, and with the price of 60's getting stupid, it may be a better deal to get a NP 205, d-shaft and front 60 from a ford and swap it all over. I guess you get even get the tranny and swap out the bellhousing too. Just an alternative.
    Jeff
    Hey, I will be sending you some pics of some stickers. PM me back with a price. DO NOT INCLUDE A DISCOUNT....These are not for me, they are for a local 4x4 shop, and I told him I may be able to get his stickers at a better rate than what he is paying now. Like I said, treat this as one of your ususal customers, not as one of "us".
    rob
  18. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    furds no cheeper /forums/images/icons/frown.gif
    furd 60
  19. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    no kidding if anything MORE expensive as every jeeper in the world is cutting them up to put a RR in the rear of their junk
    total waste of good parts, all jeepers should die
  20. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    junk
    LOL! tell us how you really feel about em. don't hold anything back this time. /forums/images/icons/grin.gif
