When bleeding brakes, Master cylinder cover on or off while pumping
Discussion in 'The Garage' started by Scott A, Nov 22, 2003.
  1. Scott A
    Scott A 1/2 ton status
    Apr 18, 2002
    129
    Monrovia, CA
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    on, you can't build line pressure with the cap off.
  3. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    On, you can't build line pressure with the cap off.
    Huh? /forums/images/graemlins/confused.gif
    The resevior isn't pressurized /forums/images/graemlins/rolleyes.gif
    I would leave the cap on, un-latched, just to keep brake fluid from squirting over everything. And you have to keep checking/adding fluid so you don't suck air /forums/images/graemlins/thinking.gif
  4. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    I always leave the cap off, and hood up, this way some one can watch the level as they pump the brakes, as long as you act sane there will be no spill issues /forums/images/graemlins/deal.gif
  5. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    I'm wrong for saying leave it on..so do what diesel dan says to do and.....umm leave it on /forums/images/graemlins/rolleyes.gif
  6. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    I've always done it with the cap off so I can watch the level and add more if needed.
  7. rjfguitar
    Aug 28, 2002
    9,040
    105
    california
    The lid doesn't matter... what matters is if there is fluid over the bottom of the reservor so it doesn't suck air.
  8. 88jimmy4x4
    88jimmy4x4 1/2 ton status
    Oct 19, 2003
    947
    Houston, Texas
    I just did this last week, I had the cap off and it squirted fluid all over the booster so I just placed it on there loosely and kept checking the fluid level....worked fine.
  9. I agree. Cap off, just press brake pedal slow and it wont squirt all over.
    Mat
  10. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I've always bled brakes with the cap off....and never had any spilling or squirting issues. It works for me! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
